body control module
Old Dec 23, 2007 | 05:47 AM
onemore's Avatar
Default body control module
Does any body know what the body control module does?
Old Dec 23, 2007 | 06:07 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: body control module (onemore)
it's a glorified multi-function switch
on 90-93 integras when it faults you will have issues with the wipers, rear defroster, the sound you hear if you leave your lights on when the car's off, etc
kind of a pain to remove, it's behind the interior fuse box....you'lll need a nice extension and a 10mm socket plus patience to get at it
Old Dec 23, 2007 | 06:28 AM
onemore's Avatar
ok thanks for the quick reply. It has nothing to do with the abs right
Old Dec 23, 2007 | 06:29 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (onemore)
shouldn't there should be a separate ABS control module
Old Dec 23, 2007 | 06:47 AM
onemore's Avatar
yeah the abs control module is located behind the right quater panel.
Noaman Sharif
May 3, 2017 10:03 PM
daister
Feb 23, 2007 06:43 PM
emegge
Jul 6, 2006 10:49 AM
