Compression test Questions
Old Dec 21, 2007 | 10:46 AM
skata89's Avatar
Default Compression test Questions
Ok Im about to do a compression test but should I do it with the motor warm? And whats this about putting a cap of oil in each cyclinder so I wont damage my rings? Im using the c-speedracing.com site.
Old Dec 21, 2007 | 10:58 AM
AWD Terror's Avatar
Default Re: Compression test Questions (skata89)
Motor should be warm
Old Dec 21, 2007 | 11:13 AM
kraig8's Avatar
the cap of oil is only for if your compression checks bad. if one of your pistons has bad compression you can put a cap of oil in the cylinder and if the compression jumps up to what it should be it means your rings are bad. the oil temporarily seals your rings.
j3wman
Jun 27, 2011 01:47 PM
dame-ningen
Apr 24, 2009 03:45 PM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
Soled Out
Sep 9, 2003 05:08 AM
