Ignitor Problem
Old Jan 25, 2008 | 06:41 PM
pacman_dc2's Avatar
Default Ignitor Problem
Ok my tach would jump like crazy by itself... and ive done alot of readin, and people say most likely the ignitor and to change it, well when i woke up today my gsr did'nt start, it just cranks, and there is no spark bein sent to plugs, i checked wit a screw driver in the plug wire and nuttin, my question is if the ignitor goes bad will i have that problem???
It has a about 1 1/2 year old dizzy so its not that, well at least i hope its not.. can someone help me with this... its gettin kinda cold to be daily driving a bike here in el paso lol
Old Jan 25, 2008 | 06:46 PM
Blahblah718293's Avatar
Default Re: Ignitor Problem (pacman_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pacman_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">It has a about 1 1/2 year old dizzy so its not that, well at least i hope its not.. can someone help me with this... its gettin kinda cold to be daily driving a bike here in el paso lol</TD></TR></TABLE>
it could be the dizzy, since its an internal coil id bet you its somewhere in there.
are you getting fuel as its cranking? if you get fuel when the key is turned on, but not when your cranking, and your getting no spark, you may have a bad crank sensor.
the only way i know of to test a crank sensor is with an oscilliscope, and i doubt youve got one of those.
and **** you think its cold there? try riding in conneticuit. at least you dont HAVE to put your bike down for the winter.
Old Jan 25, 2008 | 06:49 PM
pacman_dc2's Avatar
Default Re: Ignitor Problem (Blahblah718293)
oh nah man, im really pretty positive that its something in the dizzy... cuz ive had problems wit it, i replaced cap and rotor and it stopped jumping and hesitating, and it started jumping again, hesitating and then just stopped workiin
Old Jan 26, 2008 | 03:25 PM
pacman_dc2's Avatar
bump
Old Jan 26, 2008 | 03:33 PM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 &raquo;</TD></TR><TR><TD CLASS="quote">
i'll put $100 on it being the coil, not the distributor...while the coil and ignition module are internal to the distributor, both can be removed, tested, and replaced
if you want the coil tested, you can either do it yourself, or go to your local autozone. either way, all that is required is an ohm meter and the tolerable range for the primary and seconday of the coil.
basically, if the resistance is within those 2 tolerable ranges, the coil is fine. if it goes outside, either lower or above, it is junk. since the coil is based on resistance, this should be pretty obvious.
Old Jan 26, 2008 | 04:47 PM
pacman_dc2's Avatar
Default Re: Ignitor Problem (GRAF-FITI)
thankx man... ima go to autozone and test it tomorrow
Old Jan 28, 2008 | 04:45 PM
pacman_dc2's Avatar
does anyone know if the dizzys from ebay's distributor king are good
Old Jan 28, 2008 | 06:52 PM
i wouldnt trust a distributor from ebay. the coil can be removed anyway, or you could get an aftermarket one... msd makes an external coil.
av_shadow700
Honda Motorcycles
Jun 7, 2011 08:25 PM
HondaAccordTdR
Honda Motorcycles
11
Mar 3, 2008 07:50 AM
KaliBird
Honda Motorcycles
Oct 22, 2004 01:17 PM
Thasty
Honda Motorcycles
30
Mar 8, 2004 11:11 AM
