Problem
Old Jan 28, 2008 | 10:52 AM
disfilam04's Avatar
Default Problem
Hey guys i have a 95 ls, and i recently ran into a problem but i dont know what it is... when im driving, i hear a squeeling coming from the drivers side front wheel but it only happens when i turn the wheel slightly to the right, and when im making a right for left turn at low speed the squeel is louder when i turn to the right, when i turn to the left it sounds like knocking with each rotation of the wheel.. and input is greatly appreciated.. Also i did check for the brakepads and i wouldnt suspect that to be any problem.
james
Old Jan 28, 2008 | 11:36 AM
disfilam04's Avatar
Default Re: Problem (disfilam04)
any feedback at all on this one??
Old Jan 28, 2008 | 11:37 AM
IZEONLI's Avatar
try looking at ur cv boots and joints one good sign is that there will be a lot of grease around the inside of the rim. if the boots have been torn 4 a while then ur joints r starting 2 go. n that could be the noise ur hearing. check it out n get bak.
Old Jan 28, 2008 | 11:49 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Problem (IZEONLI)
Old Jan 28, 2008 | 11:51 AM
disfilam04's Avatar
ya there is grease... hard fix??
Old Jan 28, 2008 | 11:57 AM
IZEONLI's Avatar
Default Re: (disfilam04)
not really u will need a 32 mm socket to the hub bolt out and unbolt the axle from the tranny. the boot is held on by some clips or straps. pull those off and the boot should slide off. now u can try just replacing the boot but if it has been torn for a while u could have damaged the joint ur call on that. but i personally would replace the other side as well.
Old Jan 28, 2008 | 12:19 PM
disfilam04's Avatar
any real write ups on this?? also.. special tools any thing to look out for?
xkrntamax
Honda Civic (2006 - 2015)
Sep 13, 2008 07:25 AM
rapgonrn
Honda Civic (2001 - 2005)
Jun 13, 2008 01:22 PM
yesSiReK
11
Nov 21, 2006 11:20 AM
dashrink
Aug 24, 2005 02:19 AM
