Front upper control arm self locking nut
Old Jan 26, 2008 | 11:14 PM
TB123's Avatar
Default Front upper control arm self locking nut
My Helms manual says that when the front upper control arms are removed, the two nuts that hold the control arm to the strut tower need to be replaced. It says that they are self locking and need to be replaced every time they are removed. My question is, do they absolutely need to be replaced? Could I reuse them and put some loctite on them? I don't want to have to wait for the dealership to ship new ones to me.
Old Jan 27, 2008 | 07:35 AM
IN VTEC's Avatar
Default Re: Front upper control arm self locking nut (TB123)
Run a tap through them, apply anti-seize compound and reuse them. Do not apply thread locker. That's what the cotter pin is for.
Old Jan 27, 2008 | 08:30 AM
TB123's Avatar
Default Re: Front upper control arm self locking nut (IN VTEC)
The nuts that I am talking about do not have cotter pins. I am talking about the nuts on the strut tower, inside of the engine bay. They connect the upper arm to the strut tower. There are two on each side of the engine bay.
Old Jan 27, 2008 | 08:35 AM
Jamie98RS's Avatar
I have never replaced mine, I just reused them, but I did notice one was loose after 200km, tightened it back up.
Old Jan 27, 2008 | 08:39 AM
BryanM.'s Avatar
Resident Gearhead
My understanding is that those nuts a slightly oval so they "bite" the bolt effectively locking to them. Every replacement UCA I've seen comes with them.
Nail them with a hammer to oval them again. Just kidding
Old Jan 27, 2008 | 08:49 AM
TB123's Avatar
Default Re: Front upper control arm self locking nut (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">Every replacement UCA I've seen comes with them.</TD></TR></TABLE>
I have a Skunk 2 Pro Plus kit. I bought it new from someone here on H-T, but it did not come with replacement nuts. Do you know if it was supposed to? Maybe S2 can send me some. If not, do you think that loctite will be good enough? Thanks
Old Jan 27, 2008 | 09:37 AM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TB123 &raquo;</TD></TR><TR><TD CLASS="quote">
I have a Skunk 2 Pro Plus kit. I bought it new from someone here on H-T, but it did not come with replacement nuts. Do you know if it was supposed to? Maybe S2 can send me some. If not, do you think that loctite will be good enough? Thanks</TD></TR></TABLE>
No, I was really refering to stock replacement UCAs. That's pretty weak that S2 didn't give you any with yours, seeing how much they charge.
If it was me, I would get the correct nuts but that's just me.
The Jar
Feb 23, 2013 10:22 AM
vashnlol
Suspension & Brakes
Jan 14, 2011 06:48 AM
thedudefromjerz
Nov 10, 2006 02:50 PM
turbo92subaru
Sep 13, 2005 12:25 PM
Civic89
Aug 25, 2002 07:37 AM
