check engine light..please help
Old Jan 24, 2008 | 04:06 PM
lsvtec2000's Avatar
Default check engine light..please help
im clueless about what is goin on with my car..so im driving down the street and all of a sudden im getting no power to the car when i step on the gas..then i start pumping the gas a the start gettin power again..this went on for like thirty seconds..the car was still on motor was still running..everything normal but when i step down on the gas nothing was happening..no rpms no nothing..i was jus cruising...then a the check engine light comes up and my car is fine..it drove fine and everything..the thing is when i turn my car off and let it seat..and start it to drive again..no problems..then all a sudden the same **** happens again..dnt know whats wrong..hopefully someone can help..o yea could the crank position sensor have something to do with this..someone please help me out
Old Jan 24, 2008 | 04:09 PM
98BabiGs-T's Avatar
Default Re: check engine light..please help (lsvtec2000)
Is the CEL still on... if it is go get it read/get the code.
Old Jan 24, 2008 | 04:13 PM
lsvtec2000's Avatar
i have a different computer..then what my car came with...and i cant read the codes
Old Jan 24, 2008 | 04:21 PM
B18CYAAA's Avatar
Default Re: (lsvtec2000)
is it obd2
Old Jan 24, 2008 | 07:53 PM
lsvtec2000's Avatar
my ecu is a obd1
Old Jan 24, 2008 | 08:03 PM
se_hatchback's Avatar
hey bro it could be a faulty tps sensor.. that sound like what happend to my old crx..
Old Jan 24, 2008 | 10:43 PM
ls19integra95's Avatar
Default Re: (se_hatchback)
right above the kick panel under the dash on the driver side there should be two connectors that are in a little green rubber holder, the one connector should only have two wires going to it... pull that one out and jump it by bending a paper clip into a U and then turn the car to the on position with out actually starting it.... the CEL should start blinking... count how many times it blinks and that will tell you what code it is...
i was told to do this by a really good tuning shop round where i live and i will try and find the website where you can go look and he has on it what eash code number is...
Old Jan 24, 2008 | 10:45 PM
Default Re: (ls19integra95)
ok here it is, it explains how to do it, where the connector is and what each code is and how to read it... it has the code numbers for if its a sensor or electrical...
http://www.evans-tuning.com/te....html
Modified by ls19integra95 at 12:26 AM 1/25/2008
lsvtec2000
Jan 25, 2008 12:18 PM
lsvtec2000
Jan 24, 2008 07:54 PM
kinvid22
Jan 20, 2007 09:17 AM
xbn83
Jan 10, 2005 08:07 AM
fe519
Dec 29, 2002 06:56 PM
