B18B1 question
Old Feb 25, 2008 | 05:16 AM
acura95integra's Avatar
Default B18B1 question
Im building my b18b1 ls motor, and boosting it. my friend told me to go with a oem type r water pump and oem type r oil pump.
Now would that be the thing to do or should i leave it stock. my freind said leaving it those pumps stock could give you a bigger chance of blowing the motor.
PLEASE HELP O E M type r water pump and oil pump???
Old Feb 25, 2008 | 05:19 AM
jhammond_82's Avatar
Reject Papi
Default Re: B18B1 question (acura95integra)
you could change them. or you could be like every other tom dick and harry that have boosted ls' and leave them stock and run them for the next couple years.
Old Feb 25, 2008 | 05:33 AM
Default Re: B18B1 question (jhammond_82)
so your saying go with the type r pumps.
and if i do it says its for a b18c1 dohc vtec. these parts will
still bolt up to my non vtec block without modifications right??
Old Feb 25, 2008 | 03:47 PM
NAmodified's Avatar
my pumps r type r!!!!!!!!!!
oem itr water pump requires the use of a vtec timing belt
all dc2 oil pumps are the same
check my sig for my car.
Old Feb 25, 2008 | 04:09 PM
turboteggsr's Avatar
Default Re: B18B1 question (NAmodified)
I dont think its a necessity, but it wouldnt hurt. And like someone said earlier you match timing belt to water pump.
Old Feb 25, 2008 | 04:17 PM
Mireku667's Avatar
Im doing the same build on my B18b1 block with a b16a2 head. Yes you can use either a GS-R or Type R water pump on the block without fear of it lining up or fitting and if you do make sure you use the same timing belt for whatever bump tou use.
But be aware that the GS-R and Type R water pumps have 22 teeth where as the b18b1 has 19 teeth. Having more teeth will actually help you if your running in the high rpm range, because the water pump will pump slower than the factory pump making sure the water is be pushed and circulated through out the engine.
Rock on dude
Old Feb 25, 2008 | 04:24 PM
Default Re: B18B1 question (Mireku667)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mireku667 &raquo;</TD></TR><TR><TD CLASS="quote">But be aware that the GS-R and Type R water pumps have 22 teeth where as the b18b1 has 19 teeth. Having more teeth will actually help you if your running in the high rpm range, because the water pump will pump slower than the factory pump making sure the water is be pushed and circulated through out the engine.
Rock on dude</TD></TR></TABLE>
yeah avoiding cavitation is not a bad thing.
Old Feb 28, 2008 | 02:55 PM
Default Re: B18B1 question (turboteggsr)
i heard that with the type r oil pump its alright to change but
sometimes it can do more harm than good. the type r oil pump
might, in general, push alittle too much oil sometimes that if
neccessary for the turbo and in all real;ity you somewat lose power
instead of gaining power
julianbc2
Apr 4, 2010 11:59 AM
stevenDAtegra
Dec 15, 2008 07:53 AM
airmaxbri
Jun 3, 2008 11:49 AM
soon2bdropped
Jul 22, 2007 11:33 AM
VWkila
Jan 29, 2003 02:09 PM
