b16 in dc2
Old Feb 25, 2008 | 02:01 AM
accordin 2 me's Avatar
Default b16 in dc2
ok so i have a 97 integra LS its of course obd2a, well i just bought a b16a2 from a very cool person on this board(had to drive 300 miles but for 600 bucks i cant complain) my question is what harness would be best to use? he gave me the obd2b harness but im not sure if it just plugs up or not....what will i have to swap out if anything??? i have an obd1 gsr ecu and the conversion harness but what else will i need??? thanks guys the only reason i ask is because when i had a b16a2 in my eg hatch i used the obd2a gsr harness and it plugged in perfectly like the faq said.
Old Feb 25, 2008 | 06:13 AM
crazyguy's Avatar
Default Re: b16 in dc2 (accordin 2 me)
it is a direct drop in and bolt on. except on the driver side motor mount bracket on the b16 engine . u can swap that bracket with your LS and then u can reuse all your LS motor mounts, rear t bracket.shift linkage , axles.and everything .even the LS throttle cable. and p72 ecu wont work because air and fuel ratio is different.u can get a chipped p28 ecu or p30 or p05. or get that p72 ecu chipped and u can reuse exhaust manifold and down pipe from your LS and it will bolt right on to b16a engine and your cat convertor
Old Feb 25, 2008 | 07:04 AM
thanks man, hopefully ill see my baby back on the road tonight
ek9ina
Mar 13, 2014 09:30 PM
1990hf
Jan 24, 2009 11:27 AM
redrusch
Sep 11, 2007 09:24 AM
B16A3Civic*Eg
May 5, 2006 08:26 PM
89silverb16crx
Mar 18, 2004 10:10 PM
