94 ebs problem and dying
Old Feb 25, 2008 | 01:02 PM
kslimm0714's Avatar
Default 94 ebs problem and dying
ok i have a 94 ls all stock i bought new headlights they are 100w ok worked fine for a few hrs then let my girl take it to pick up food then she turned it off then it wouldn't start so i jumped it it started right out so i thought it was the batt or the alt but the car is reading out 13.5volts so that's okay but now the abs light comes on then when i turn on my lights the car shuts off i took out new lights and put old ones back in and still have problems so please if someone can help thank you
Old Feb 25, 2008 | 03:28 PM
95 integra's Avatar
Default Re: 94 ebs problem and dying (kslimm0714)
Sounds like you fried some electrical circuits by running larger headlights then what you were suppose to...
Old Feb 25, 2008 | 03:54 PM
kslimm0714's Avatar
Default Re: 94 ebs problem and dying (95 integra)
ok so where do i look to check on what i need to replace
Old Feb 25, 2008 | 05:18 PM
Dogginator's Avatar
Daisy... Daisy...
Pull the codes for the ABS. It will tell you why the light is on. The FAQ thread has a link.
You replaced a 55W bulb with a 100W bulb. Look in the Helm manual for wiring diagrams.
Old Feb 27, 2008 | 07:55 AM
kslimm0714's Avatar
Default Re: 94 ebs problem and dying (Dogginator)
ok the car still starts and runs but the abs light stays one there is a clicking sound coming from the thing by the left headlight with a bunch of lines coming out of it and it says only full with dot3 what does the clicking mean?
Old Feb 27, 2008 | 08:18 AM
Dogginator's Avatar
Daisy... Daisy...
Pull the ABS codes and it will tell you the problem.
Old Feb 27, 2008 | 10:45 AM
kslimm0714's Avatar
where can i pull the codes from and how do i know what code it is this is all new to me and i don't wanna take it to a dealer
Old Feb 27, 2008 | 11:13 AM
Dogginator's Avatar
Daisy... Daisy...
Look at this thread. It is listed in the FAQ.
https://honda-tech.com/zerothread?id=978933
rhijada
Jan 6, 2013 01:37 PM
funz0rzies
Honda Civic (2001 - 2005)
Dec 28, 2008 12:36 PM
babeeson1
Feb 14, 2007 04:27 PM
revhigh89
Jan 31, 2004 06:58 AM
