quick ls/vtec question
Old Feb 26, 2008 | 06:45 PM
pokmijn's Avatar
Default quick ls/vtec question
to some of you this might be a stupid question but i need to know thats why im asking....if i go ls vtec do i have to change the water pump to a vtec on because when i read the forum how to build i realiable ls/vtec it didn't say must change water pump it say use ls timing belt if use ls water pump so is it ok to use the ls water pump. i need to know so i can go get one.
Old Feb 26, 2008 | 06:53 PM
96integralsvtec's Avatar
Default Re: quick ls/vtec question (pokmijn)
buy a gsr or itr water pump.....and......gsr or itr timing belt....thats the best thing to do with the water pump and timing belt
Old Feb 26, 2008 | 06:56 PM
pokmijn's Avatar
Default Re: quick ls/vtec question (96integralsvtec)
ok thanks a lot i dont want to do something thats gonna mess up my build easily. because this will be my first ls/v build.
Old Feb 26, 2008 | 07:02 PM
pokmijn's Avatar
oh one more question since im gonna use a 91 ls block do i have to add a knock sensor.
Old Feb 26, 2008 | 07:12 PM
well your gunna need to get it tuned so when you get a chipped ecu it will eliminate the knock sensor.what is your whole setup?block,tranny,head,internals,shell?
Old Feb 26, 2008 | 07:31 PM
pokmijn's Avatar
well this is what i got right now b18a1 block b16a head
the head
type r vavle train retainers and cams
the block
ctr piston
ls rods
ls crank
wrist pin
bearings
arp rod bolts and head
going into a da
with a gsr tranny
Modified by pokmijn at 8:42 PM 2/26/2008
Old Feb 26, 2008 | 08:26 PM
nice setup.my boy has close to the same the only thing is when the tuned ecu cuts out the knock sensor you might not be able to pass for inspection.that's how it is in ma at least.unless you bring it to someplace that don't care bout anythin like me.lol I'd never be able to pass an inspection if I went to a legit place lol.but that's what my boy did too just so you know in advance.
Old Feb 27, 2008 | 06:45 PM
pokmijn's Avatar
i know i wont get pass inpection want kind of power is your boy making and what should i be making do you know i just want to know so i can look forward to it.
Old Mar 2, 2008 | 03:18 PM
idk exactly but hes probly making round 190.
WhiteEJCoupe
Sep 16, 2006 10:03 AM
Battle Cat
Apr 30, 2005 10:21 AM
dabrown
Jun 25, 2004 02:43 PM
