timing problem
Old Feb 27, 2008 | 11:24 AM
matmcg's Avatar
Default timing problem
So I changed my distributor to an older one from a DA and rewired it to fit my DC
So now when I turn on the car it takes a long time to crank and eventually turns on but goes all strange it will shake horribly and rev up and down and when i pushthe gas it will turn off
If it ever turns on properly it dies after 2 seconds
I believe its a timing issue what can I do
Old Feb 27, 2008 | 11:25 AM
95 integra's Avatar
Default Re: timing problem (matmcg)
Get the correct distributor/fix your improper wiring job. It could be a "bad" distributor, however I would assume you didnt wire something up correctly.
Old Feb 27, 2008 | 11:54 AM
matmcg's Avatar
could the wiring mistake possibly be causing this problem?
HungLoSavage
Transmission & Drivetrain
Sep 3, 2010 07:03 AM
jakscivic
Jun 2, 2010 07:29 PM
ek fan
Jul 4, 2008 04:47 AM
jakscivic
Apr 28, 2006 11:10 PM
