TPS sensor issue on a gsr?
My 98 gsr is completely bone stock. I just recently had an idle issue. When at normal operating temp, the car idle's fine, between 750-850 rpm. But when driving and coming to a complete stop in neutral. The idle will suddenly jump up to ~1800 and down to ~1000. It will do this for about a minute or two, of the idle jumping. Then after, the idle will go back to normal. I've already cleaned out the IACV, and this has been occuring, when driving for the first 10-15 minutes after start up.
There are no CEL's at all, and the car already had a full tune-up prior to this issue. So today, I opened the hood to inspect what the problem could be. And went straight to the TB area, I looked at the TPS thinking maybe it's the sensor or the wiring. And Bingo!, I slightly moved the TPS wiring and plug around, and the idle would act up. But If I moved the wiring or plug a certain way, the idle would't jump around. I'm thinking either the wiring or plug on the TPS could be frayed/bad, or the TPS sensor could be faulty. Then again if it's a faulty TPS sensor, there would be a CEL correct?
If it is a bad TPS sensor and I get it replaced. The new TPS sensor needs to be calibrated correct? If so, how would I calibrate it?
Anyone have such problem? Maybe redo the TPS wiring? Change the TPS plug or TPS sensor? Any ideas would help, Thanks!
Re: TPS sensor issue on a gsr? (VTECth1s)
if its disconnected it may throw a code, its possible it may not though
connectors are no prob to replace, same with tps. and no you dont need to calibrate the tps. just figure out which you need, the sensor or the connector. or just go to a junkyard and pick both off.
Re: (emooheo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emooheo »</TD></TR><TR><TD CLASS="quote">that sucks. yes you willl have to calibrate the TPS. its pretty easy actually</TD></TR></TABLE>
Please, explain the procedure.
after you put the new tps on, you will need to use an ohm meter and adjust the tps until the ohm meter reads .45v at closed throttle. its simple. i got a brand new omni tps if you are interested
Re: (patrick4588)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 »</TD></TR><TR><TD CLASS="quote">after you put the new tps on, you will need to use an ohm meter and adjust the tps until the ohm meter reads .45v at closed throttle. its simple. i got a brand new omni tps if you are interested</TD></TR></TABLE>
exactly right, i replaced mine, and my car ran funny until i calibrated it.
Re: ([ iLL ] iNt3GrA)
i would also like to know where you stick the ohm meter lines to check the resistance. hey i had this problem too. my car would run like **** with half a throtlel, i was using an after market tps sensor. i switched it with an oem one and the problem went away. just find a oem sensor and it should fix it. i just need help calibrating it.
