Your thoughts on this
Old Feb 25, 2008 | 11:16 PM
jdmkid8383's Avatar
Default Your thoughts on this
My 91 RHD da is making me scratch my head
ok i replaced the dizzy,
new starter
new battery
new spark plugs
when i drive it in first at low RPM its koo
but when i step on the gas it boggs out and sometime the whole car shuts off
what are your thougts??
Old Feb 26, 2008 | 04:03 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Your thoughts on this (jdmkid8383)
What if you ease into the throttle? Will it run at higher RPM and partial throttle?
I'll guess fuel filter from the limited information.
Old Feb 26, 2008 | 04:07 AM
AsSanitySlipsAway's Avatar
^ thats the first thing i thought about as well.
Old Feb 26, 2008 | 05:02 AM
what gsr's Avatar
Default Re: (AsSanitySlipsAway)
good thing you told us its right hand drive instead of telling us what motor it has..
Old Feb 26, 2008 | 05:08 AM
polishedturd's Avatar
I like PIE
Default Re: (what gsr)
ive got $100 on fuel pump! and while your at it change the filter also, cheap&easy.
Old Feb 26, 2008 | 05:37 AM
jdmkid8383's Avatar
Default Re: (polishedturd)
b20 non vtec
Old Feb 26, 2008 | 08:50 AM
james_ls's Avatar
Is your timing correct?
Old Feb 26, 2008 | 09:14 AM
jdmkid8383's Avatar
Default Re: (james_ls)
yes sir timing correct..
When I start the car it runs perfect just sitting there idle is perfect like 900
but when I start to drive it it boggs out than shuts off the motor everything else is on the lights,radio,and so forth just the motor shuts off...
Still scratching my head
Old Feb 26, 2008 | 11:44 AM
JDM.'s Avatar
First thing I thought of was that it could maybe be a injector problem or even maybe a electronic problem.... like the coil or the entire distributor...
Old Feb 26, 2008 | 11:54 AM
jdmkid8383's Avatar
Default Re: (JDM.)
Engine starts but stops immediately
- Loose or faulty electrical connections at distributor, ignition coil or alternator.
- Insufficient fuel reaching the fuel injectors.
- Vacuum leak at the gasket between the intake manifold and throttle body.
__________________________________________________ _______________
Engine stumbles on acceleration
- Spark plugs fouled.
- Fuel injection system faulty.
- Fuel filter clogged.
- Incorrect ignition timing.
- Intake manifold air leak.
Engine surges while holding accelerator steady
- Intake air leak.
- Fuel pump faulty.
- Loose fuel injector wire harness connectors.
- Defective ECU or information sensor.
Engine stalls
- Idle speed incorrect.
- Fuel filter clogged and/or water and impurities in the fuel system.
- Distributor components damp or damaged.
- Fault emissions system components.
- Faulty or incorrectly gapped spark plugs.
- Faulty spark plug wires.
- Vacuum leak in the fuel injection system, intake manifold or vacuum hoses.
- Valve clearances incorrectly set.
Mcdc2's Avatar
Default Re: (JDM.)
What about spark wires? Change those yet?
Old Feb 26, 2008 | 12:55 PM
IVI's Avatar
IVI
Default Re: (Mcdc2)
TPS working correctly? how easy are you on it in first?
WestyNaut92
31
Nov 1, 2017 02:27 PM
mouab18c1
Jan 22, 2011 07:38 PM
teg racer 877
Apr 7, 2010 09:53 PM
jimmy o.
13
May 16, 2009 08:36 AM
94eg!
Aug 15, 2007 02:01 PM
