integra slows down in freeway
Old Mar 30, 2008 | 09:06 PM
lazyxmofo's Avatar
Default integra slows down in freeway
when i hit the freeway...going about 80 mph...my speed starts to drop and my 90 integra doesnt want to go pass 3000 RPM....the rpm just keeps dropping lower and lower...then suddenly go back up at times...have this happend to anyone?
Old Mar 30, 2008 | 09:31 PM
TOO MUCH TORQUE's Avatar
its called engine breaking
Old Mar 30, 2008 | 09:37 PM
Apathy47's Avatar
Default Re: (TOO MUCH TORQUE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">its called engine breaking</TD></TR></TABLE>
so is that what happened when I swapped my transmissions? I had a similar experience.
Old Mar 30, 2008 | 09:52 PM
lazyxmofo's Avatar
Default Re: (Apathy47)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apathy47 &raquo;</TD></TR><TR><TD CLASS="quote">
so is that what happened when I swapped my transmissions? I had a similar experience. </TD></TR></TABLE>
does yours run perfect like for about 5 miles then slows down on itself? rpm dropping lower and lower even when you downshift?
Old Mar 30, 2008 | 09:57 PM
Apathy47's Avatar
Default Re: (lazyxmofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyxmofo &raquo;</TD></TR><TR><TD CLASS="quote">does yours run perfect like for about 5 miles then slows down on itself? rpm dropping lower and lower even when you downshift? </TD></TR></TABLE>
yep. that's how it was after the swap. but after that incidence, the car ran normal and no problems. no issues now...
Old Mar 30, 2008 | 10:10 PM
lazyxmofo's Avatar
did you change anything?
Old Mar 30, 2008 | 10:33 PM
Apathy47's Avatar
No. I'm pretty sure my situation was different then yours. seem like a simple break in for the tranny.
Old Mar 30, 2008 | 11:05 PM
beatthisspeed69's Avatar
check ur dizzy like the rotor may be lose or something thats wat was wrong with mine then i changed the rotor no more problem
Old Mar 31, 2008 | 09:21 PM
lazyxmofo's Avatar
Default Re: (beatthisspeed69)
iight thanks ill take a look at that
looie
Mar 1, 2008 01:46 PM
gsrcandyman
Sep 30, 2007 07:43 PM
atsyuo
Dec 2, 2005 08:52 PM
Mr_Moos
May 27, 2005 06:32 AM
