Spark plug problem.
Old Mar 30, 2008 | 08:36 PM
Loveless.'s Avatar
Default Spark plug problem.
1998 LS
Story:
Engine was rebuilt by me, my dad (mechanic) and the service manual.
New Piston Rings
New Connecting Rod Bearings
New Head Gasket
Head was sent to machine shop for valve job and hot tank
New Cap and Rotor
NEW SPARK PLUGS. NGK V-Power gapped @ .044
oil flushed at 1000 miles and replaced with 5w30 full syn
car runs 91 octane
after about 3000 miles engine started having poor cold starts. It was misfiring. I thought it was an idle problem so i replaced the IACV. Didnt seem to help. Today I removed my spark plugs and noticed that all four were FOUL. I replaced them and it solved my problems..
anyone know what/why the spark plug looks like this after only 3000 miles?
Modified by Loveless. at 9:44 PM 3/30/2008
Old Mar 30, 2008 | 09:56 PM
Its that kidfolk's Avatar
Default Re: Spark plug problem. (Loveless.)
damn......
<FONT COLOR="green"><FONT SIZE="40">WHAT THE ****!!!</FONT></FONT>
just drop a "K"ids series in there and call it a day like them other people
Old Mar 31, 2008 | 06:31 AM
lmike6453's Avatar
o2 sensor or air cloggage, but you cleaned your airflow
Old Mar 31, 2008 | 07:02 AM
itslogz's Avatar
Default Re: (lmike6453)
http://www.spark-plugs.co.uk/p...s.htm
see if you can compare it to any of those.
Old Mar 31, 2008 | 08:17 AM
Loveless.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">o2 sensor or air cloggage, but you cleaned your airflow</TD></TR></TABLE>
i do have a CEL for o2 sensor. i will replace it today. i did not know tha the o2 sensor can cause that.
Old Mar 31, 2008 | 09:50 AM
Loveless.'s Avatar
Default Re: (Loveless.)
found the problem.
head gasket is messed up.
i might have bent it when i put on the head.
saw water in cyl #1 while doing a compression test.
Old Mar 31, 2008 | 05:48 PM
migee's Avatar
Wow didnt know that could do those to all 4 sparkplugs... glad you found out what it was.
tonyw85
May 5, 2008 02:17 PM
n8byte
Oct 28, 2005 04:36 PM
WTB AUTO EK
Feb 14, 2005 12:25 PM
nek0
Jun 8, 2003 11:15 AM
Doogie Howser
May 22, 2002 11:59 AM
