leaking problem
Old Mar 30, 2008 | 10:16 AM
zc89hatch's Avatar
Default leaking problem
i have a 94 integra ls and its leaking at my clutch pedal
what does this mean? help!!!
Old Mar 30, 2008 | 10:20 AM
Rikter's Avatar
Trace the leak back to the clutch master cylinder.... or is it the slave? Anyway, one of those is leaking unless you have a rupture in the line somewhere.
Pop open your hood...... look inside.... find which part is soaked in fluid. That'll be your problem.
-Rik
Old Mar 30, 2008 | 11:03 AM
lmike6453's Avatar
it's the clutch master cylinder-make sure to top off fluid when reservoir gets low
Old Mar 30, 2008 | 01:17 PM
zc89hatch's Avatar
Default Re: (lmike6453)
well its leaking inside the car at the clutch pedal
so do i need to change out the clutch master cylinder
Old Mar 31, 2008 | 05:51 AM
lmike6453's Avatar
yup, i would replace the pin while you're at it if you're going the keep the car for 5 yrs or more
Old Mar 31, 2008 | 11:22 AM
zc89hatch's Avatar
what pin are you talking about
Old Apr 1, 2008 | 05:37 AM
lmike6453's Avatar
i think it's called the cotter pin that goes through the pedal itself...you're going to have to remove it anyhow to replace the master cylinder
WillyD
Transmission & Drivetrain
Oct 1, 2011 10:04 PM
duyfash0
Mar 21, 2010 04:08 PM
josejdm
Oct 7, 2009 02:22 PM
Dr. Phil
Sep 24, 2007 04:52 PM
aengnr1
Jun 16, 2003 12:23 PM
