Are these illegal?
Old Apr 1, 2008 | 02:20 PM
Nicks95GSR's Avatar
Default Are these illegal?
http://www.prostreetonline.com...s.asp
and these
http://www.prostreetonline.com...t.asp
Thanks!!!
Old Apr 1, 2008 | 02:31 PM
turboteg90's Avatar
pm for noodz
Default Re: Are these illegal? (Nicks95GSR)
no,i got stage 2 cams and they are loud
Old Apr 1, 2008 | 03:03 PM
nicks-eg6's Avatar
Default Re: Are these illegal? (turboteg90)
probably not..... but there probably junk
Old Apr 1, 2008 | 03:24 PM
fcfromhell420's Avatar
Default Re: Are these illegal? (nicks-eg6)
technically yes, damn near any modification to a vehicle is, but nobody knows what you have inside the engine, as long as you can pass emissions you'll be fine
Old Apr 1, 2008 | 04:07 PM
Audiojb's Avatar
get ferrea valves
Old Apr 2, 2008 | 08:49 AM
Nicks95GSR's Avatar
Default Re: (Audiojb)
Will my car pass SMOG w/ these mods???
Old Apr 2, 2008 | 09:37 AM
0930_SI's Avatar
Default Re: (Nicks95GSR)
They are not junk u retard, blox type a are good and u might be able to pass smog i know other people that have but it also depends on what else u have on the car. Type a's are good they r better than type r cams, if you have pretty high compresion you should go with type b's. I haven't heard any bad things about blox cams, do a quick search, there's some good dyno numbers on the all motor dyno thread.
Old Apr 2, 2008 | 09:41 AM
0930_SI's Avatar
Default Re: (0930_SI)
As far as retainers and springs i havent heard bad things about omni eaither but i went with supertech springs and crower retainers. Also i didnt get the titanium cuz im daily driving my car and they dont last as long i just went with the chromoly retainers that are lighter than stock and still strong and durable.
Old Apr 2, 2008 | 10:07 AM
Nicks95GSR's Avatar
My DC2 is also my Daily Driver. So what retainers and springs do you reccomend for a Daily Driver with a short ram Intake, Greddy EvoII catback exhaust, BLOX intake mani and throttle bodie? Oh yea Im looking into getting the type B cams.
Thanks!!1
Old Apr 2, 2008 | 12:04 PM
0930_SI's Avatar
type b's will only benifit you more than a's if you build your motor more, like higher compresion pistons, type a's will do better with your mods. I'd go with supertech.
Old Apr 3, 2008 | 10:33 AM
Nicks95GSR's Avatar
orite ima look into that!!!
Old Apr 3, 2008 | 10:44 AM
all-mtr-teg's Avatar
I got the Blox B's in my weekend car, and had BC'3 in my DD. The B's like CR higher than stock, like 11:1 - 12:1. I ran BC's in my daily driver when it only had a stock GSR bottom head and a semi built head, and the low and mid range was great.
Old Apr 3, 2008 | 12:15 PM
A's 94 GSR's Avatar
BG-33P
Default Re: (all-mtr-teg)
I think the op is just doing a 'building block' type of build. OP, what are your intentions with your motor?
Old Apr 4, 2008 | 09:40 AM
Nicks95GSR's Avatar
Default Re: (A's 94 GSR)
I just wanna get up to the 200'sWHP not much but will do...
Old Apr 4, 2008 | 09:44 AM
0930_SI's Avatar
200 whp u gonna need some internals, maybe a 81.50 bore with higher compression pistons.
Old Apr 4, 2008 | 09:53 AM
Nicks95GSR's Avatar
I was thinking of doing that however I was planning to get the valve train replaced, Cams (tuned), and cam gears before I got the pistons and rods. But bro its gonna make a BIG AZZ whole in my wallet, I'm looking at what? a good $1500 (including labor) if not more...
Old Apr 4, 2008 | 10:43 AM
0930_SI's Avatar
yeah, do the head first, im doing kinda the same, just wait and look for good deals on here, some on ebay i guess, there's always people that want a different project etc.. and sell stuff for cheaper, i got a hell of a deal on springs reatiners and cams, but im also gona get a gsr bottom with pr3 pistons, but thats more of a project.
Old Apr 6, 2008 | 09:08 PM
Nicks95GSR's Avatar
It must feel good to have money...
Old Apr 8, 2008 | 01:40 PM
Audiojb's Avatar
pistons and rods will run you about 800-1000
block work - bore, etc 500~
valvetrain - 500~
headwork - p&p, etc 800~
cams - 400-600~
ive spent over 5500 on my build and ill be lucky to get 220whp
Modified by Audiojb at 12:03 PM 4/10/2008
igorka_91
Jan 1, 2012 11:45 AM
p3t312
Dec 30, 2011 07:48 AM
is3oo
Mar 2, 2005 01:05 PM
Grandma Humper
Jan 9, 2003 01:13 PM
B00ST2nR
May 20, 2002 12:26 PM
