Brake problem
Old Apr 1, 2008 | 07:10 PM
infamouskillas's Avatar
Default Brake problem
so yeah i kno i'm no expert with brakes or anything else in description...but i mean i need help with this slight issue that is annoying the hell out of me...everytime i start applying my brakes, my right front brake squeaks like no other...it is unreal with how annoying it is...then wen i start going, even when i'm not on my brakes, it starts squeeking, just not as much as wen i stop...idk if my pads are worn out..but to me they looked pretty good...idk if the calipers are releasing pressure properly...idk if i need to grease my brakes with a grease gun...idk if i need to change brake fluid..i need help wit this and i kno its stupid but idiot in need of help..thanx
Old Apr 1, 2008 | 07:46 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Brake problem (infamouskillas)
A constant squeak or periodic (squeak-squeak-squeak)?
Do not grease your brakes.
Missing pad shims and brake rotor runout can cause squeaking.
Old Apr 1, 2008 | 07:55 PM
Default Re: Brake problem (Dogginator)
its like both kinds of squeaks... like sometimes it'll be a constant squeak...other times it'll be periodic as if it would only squeak on one part of the disc and thats it...it annoys me so much and i'm thinkin about replacing my discs and pads...i figure i'll just upgrade em to a brembo disc and hawk pads...but the thing that's stopping me from this is the calipers...i have 15 inch wheels and i wanna upgrade my calipers too...problem is the guy at the shop says that i can't cuz my wheels are too small..is that true? if not what kind of calipers are better but cheap that will fit under 15 inch wheels?
Old Apr 2, 2008 | 05:25 AM
Dogginator's Avatar
Daisy... Daisy...
ITR calipers with 282mm rotors will fit your 15" wheels. (Your stock rototors are 262mm.)
https://honda-tech.com/zerothread?id=734560
Old Apr 2, 2008 | 07:32 AM
nsxtasy's Avatar
H-T Order of Merit
The most likely cause is worn brake pads. Have you removed the wheels to check the thickness of both pads, on both sides of the rotor (including the inside, which you can't see unless you take the wheels off)?
patrickstar
Suspension & Brakes
Apr 24, 2009 12:41 PM
mouab18c1
Suspension & Brakes
Apr 10, 2009 06:53 AM
Mi2age
Jun 14, 2007 11:48 PM
ziggz5011
Mar 15, 2007 08:00 PM
AgentJam
11
Oct 15, 2003 05:50 PM
