Problems After Installing Clutch!!!
Old May 10, 2009 | 04:39 PM
94_Teggy's Avatar
Default Problems After Installing Clutch!!!
Ok so installed a new clutch and the clutch doesnt seem to engage!wen it goes into 1st the tires spin and everything but when i go to push the clutch in to stop it no clutch....pedal doesnt really have that much pressure ethier!!any opinions!!!
-94 integra...b18c
Old May 10, 2009 | 05:08 PM
Tegraracer90's Avatar
Default Re: Problems After Installing Clutch!!!
check the master cylinder and slave cylinder...sometimes the pressure of a new clutch will make the old weak slave/master cylinder let go
Old May 11, 2009 | 02:42 AM
94_Teggy's Avatar
slave cylinder is pushing out..wat should i look for in the master?
Old May 11, 2009 | 05:08 AM
teg racer 877's Avatar
did you do it yourself? did u replace the throwout bearing? and are you sure you installed the clutch fork correctly?
Old May 11, 2009 | 10:58 AM
1992blueGSR's Avatar
cable clutch FTW!!!!!
ohsnapzafingcu
May 16, 2011 04:30 PM
b16a4
Nov 18, 2006 11:04 AM
Surestick
Aug 23, 2006 10:56 AM
s1ngle
13
Sep 21, 2005 12:01 PM
SikofFalln
Apr 25, 2003 02:49 PM
