Putting on door panel?
Old May 12, 2009 | 08:10 PM
RyanPm's Avatar
Default Putting on door panel?
I was installing my new speakers into my car, and I can't seem to get the door panel back on properly. It doesn't seem to go in all the way on the top left, and theres a small gap. The door handle and lock are kinda deep in it's hole so that I can't lock it easily with my fingers. Any tips of getting the door panel on properly?
Old May 12, 2009 | 08:16 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Putting on door panel?
what year teg. The best way to do it is to slide the top on till it clips into place and line it up to the window sil and pop it on.
Old May 12, 2009 | 08:22 PM
RyanPm's Avatar
Sorry, it's a 1995 hahah. I don't know why but I just can't seem to get the top slid in and clipped everywhere. The rubber on the top doesn't like to get close to the door on the left side. I even had my father help me out and he was swearing and we eventually just left it.
A clip broke, too. Could this be an issue? I don't see why that would cause this to happen though
Old May 12, 2009 | 08:31 PM
You kind of have to bend the top so it will cover the top of the door. It easy to do it with the door off. Its sort of like a hook on top. I would swing it by a local stereo shop and ask a install to do it. Bring a bag of chips a snapple and I bet he wont charge
Old May 13, 2009 | 04:21 AM
hondaTegGsr's Avatar
I too just installed new speakers all around. I had a little difficulty putting my panels back on. I ended up rolling the window all the way down and tilting it through the window and with just a little bit of stretching over that lip of the door and a little bump to the front it finally went back into place. Clips should pop in. ....
Old May 13, 2009 | 04:40 AM
JDM 98 GSR's Avatar
take off the littlem black cover where you side mirror blots on (looks like a triangle) thats how i did mine and it slid right in
Old May 13, 2009 | 08:15 AM
RyanPm's Avatar
Haha I have no idea what the little triangle is or the black cover where the side mirror is
Old May 13, 2009 | 09:49 AM
u cant be serious
Old May 13, 2009 | 01:38 PM
newc1's Avatar
go to a pick and pull and try it on someone else's car first.
Old May 13, 2009 | 05:38 PM
safedriver's Avatar
Roll the window down.
Keeping the rear edge tilted up at about 30 degrees, hook the front edge (that will be closest to the mirror) of the panel over the center of the door.
Have someone watch the power door connector, so it does not fall behind the panel.
Slide the panel towards the mirror and slowly reduce the 30 degree angle.
Line up the hole under the triangle with the hold in the door. (A plastic clip will go here.)
Verify the panel is hooked over the door on both sides.
Snap the front of the panel, then the lower middle, then the rear.
Old May 14, 2009 | 10:02 AM
JDM 98 GSR's Avatar
its a door panel....
Old May 14, 2009 | 10:19 AM
Kendall's Avatar
It helps to keep the panel tilted both up (as safedriver mentioned) and out a bit. Once you get it on over the mirror, the rest is easy.
RealRaw
Sep 2, 2020 05:22 PM
Rayzorx
May 30, 2011 06:46 PM
suhteevin
Jan 6, 2009 09:04 PM
chiggin
Honda Civic (2006 - 2015)
Aug 28, 2007 11:31 AM
snake01
Jan 11, 2002 09:06 PM
