ABS Function
Old May 6, 2009 | 08:00 PM
civicexowner's Avatar
Default ABS Function
I ran my abs codes and it shot code 8-1 (abs function) I searched on google to see what it was but just a bunch of math came up. Does anybody know how to fix this?
Thanks HT.
Old May 6, 2009 | 08:04 PM
DAintegraGSR's Avatar
Default Re: ABS Function
code 8-1 is abs operation fault..
Old May 6, 2009 | 08:11 PM
Hmm what exactly is that though? I'm tryin to pin point the fault.. do you know ?
Old May 6, 2009 | 08:21 PM
sorry bro, id keep searching to see if someone has had same problem witch im sure has happen.
Old May 6, 2009 | 08:24 PM
jdm_bones's Avatar
ABS function means that there is wheel sensor(s) that aren't functioning correctly or a bad ABS unit...To be sure take it to your Acura dealer, and they will plug in a scanner and locate the issue.
Old May 6, 2009 | 10:40 PM
I have OBD1 so idk if they can plug in the scanner. Is there another way i can find out forsure or do i have to start taking chances and replacing stuff.
Old May 14, 2009 | 01:55 PM
9KRevLimitDC2's Avatar
I have a spare ABS computer if you need one. LMK
Old May 14, 2009 | 02:48 PM
jdm_bones's Avatar
Believe me we have the scanner for your OBD1 Integra...
Old May 14, 2009 | 03:04 PM
DC_Legacy's Avatar
So you checked the MIL ABS light for a code, but couldnt find a code that specified the area of concern beyond the ABS function?
I dont know if this is what your looking for but it has all the General CEL codes + ABS codes
https://honda-tech.com/zerothread?id=978933
rhd
Nov 10, 2005 06:25 PM
mytegra505
Apr 23, 2004 11:40 AM
RagingAngel
Mar 6, 2003 06:43 PM
yaksplat
Aug 23, 2001 11:29 AM
