cleaned iacv now have overheating problem
Old May 10, 2009 | 11:39 PM
turboteg7's Avatar
Default cleaned iacv now have overheating problem
i have 97 gsr turbo i just rebuit the engine and it was running fine besides the idle was jumping around. i took off the iacv to clean it out. the two coolent lines the run to it leaked out all of my coolent. so i put coolent in it now my car overheats. i have my fan on a togle so its running all the time it still heats up. any sugestions please its killen me
Old May 11, 2009 | 03:06 AM
non-VTEC's Avatar
Default Re: cleaned iacv now have overheating problem
you didnt bleed the air out of the cooling system properly. you cant just add coolant and put the cap on.....there is a proper bleeding procedure.
Old May 11, 2009 | 06:46 AM
turboteg7's Avatar
no i bleed it right im pretty sure
Old May 11, 2009 | 09:38 AM
twentyhurtz's Avatar
my first response would be, you didn't bleed it either, did something get in the iacv coolant ports or clog it up?
Old May 11, 2009 | 12:32 PM
turboteg7's Avatar
all i did was clean it out with carb spray could that hurt it?
Old May 11, 2009 | 12:59 PM
wunfstgsr's Avatar
Loved
Community Favorite
No but you must bleed it let it run with the cap off until the bubbles go away, or your thermostat took a crap!
Old May 11, 2009 | 01:38 PM
turboteg7's Avatar
im waiting for my car to get cool enough to take the rad cap off and make sure its bleed last time i was doing this tho and my car started to get hot just leting it idle
Old May 11, 2009 | 09:38 PM
turboteg7's Avatar
i bleed the coolent and it dosent overheat as bad but it still does slowly if i turn my heater on high it go right to operating temp where it should be
Old May 12, 2009 | 05:41 AM
jhammond_82's Avatar
Reject Papi
maybe your radiator's shot. your hoses on tight? cap still good? no obstructions in any of the lines?
Old May 25, 2009 | 01:00 AM
turboteg7's Avatar
its been a few weeks and if i take my rad cap off and let it warm up before i drive it. it will not over heat for a while but if i dont do that it overheats right away. i was going to pull out my thermostat but the bolt got strip off so i cant do that. and my car dosent leak any coolent.
sirej809
10
Dec 30, 2009 09:52 AM
krysted9354
11
Mar 4, 2009 04:27 PM
LeArN2LiVe
Nov 22, 2008 12:08 PM
BrokenRex
Oct 20, 2005 05:52 PM
DsCivicEx
Feb 12, 2004 04:52 PM
