what is this sensor????
Old May 12, 2009 | 05:31 PM
4 door beast's Avatar
Default what is this sensor????
[IMG][/IMG]
does anybody know whta that is the car is a 4 door ls with a GSR swap when they swapped the motor they left this unplugged it connects to the throttle sensor does this need to be attached ???
Old May 12, 2009 | 05:43 PM
WDG_729_ITR's Avatar
Default Re: what is this sensor????
Looks like the sensor map is already plugged in so unless problems arise, I wouldn't worry about it.
Old May 12, 2009 | 06:13 PM
Dartanian's Avatar
Yes, you need to have both sensors plugged in. A missing MAP or TPS signal is going to cause the car to run very poorly.
Old May 12, 2009 | 06:18 PM
patdow1's Avatar
I would say it looks like a AIT Clip (Air Intake Temp)
Old May 12, 2009 | 07:28 PM
so where does it go ive looked and i dont know where that plug goes
Old May 12, 2009 | 09:08 PM
jdm_bones's Avatar
I also think it's a AIT sensor, as TPS is pluged in, and Map is pluged in.
Old May 13, 2009 | 01:14 AM
DA-Flyby's Avatar
check the areas at that connector's reach, if there nothing then I wouldn't pay no mind. You should have The AIT sen. on the top of the intake manifold by the rear. I just checked the 94-2000 integra mannual and theres nothing else that should be plugged in.
MAP.AIT,TPS, AND IAC. those are the only ones in that area
balbowskie
Feb 21, 2012 07:10 AM
B16A CRX
Jul 9, 2007 06:14 PM
GhostInTheShell
Mar 19, 2007 05:25 PM
jay-d-em
Sep 7, 2006 05:07 PM
