Bleeding clutch fluid
Old May 13, 2009 | 02:02 PM
CompanyFlow's Avatar
Default Bleeding clutch fluid
So I found a loose fitting and decided to bleed the system out 3 times due to the fact that I have slack in my pedal. I still have slack in my pedal. WHAT MORE MUST I DO TO RID ME OF THIS PROBLEM?
Old May 13, 2009 | 02:49 PM
MumBleZ_94gsR's Avatar
Default Re: Bleeding clutch fluid
maybe the slave cylinder took a dump
Old May 13, 2009 | 07:00 PM
Thats what I'm thinking, either that or it was installed incorrectly. How hard is it to replace?
Old May 13, 2009 | 08:21 PM
jdm_bones's Avatar
not hard at all, just messy...two bolts hold it in place, and clutch fluid lines...
Old May 13, 2009 | 11:18 PM
fergs96integra's Avatar
how much slack are we talking about here?
Old May 13, 2009 | 11:29 PM
95DC2GS-R's Avatar
Could be that the pedal needs adjustment.
There's articles online and you can find it in the manual on how to do it.
Old May 14, 2009 | 01:01 AM
sp00ledbseries's Avatar
Pedal needs adjusted or your master took a ****
Old May 14, 2009 | 10:04 AM
The master is fine. The master took a **** a month ago. This is what happened: Both of my tranny mounts busted and the bolts were sheared off inside of the case, so I had to have it machined and have the threads re-tapped. Im thinking that they either installed the slave incorrectly or the slave took a ****. I have been having this particular problem since I got the car back, but I noticed that the pedal would randomly lose pressure. I bled it and then a week later (a few days ago) the pedal practically took a **** on me. I popped the hood and saw A TON of fluid had just leaked out in my driveway when I got home. I noticed that the fitting closest to the bleeder valve was loose, so I tightened it up and bled the system again. The pedal is stiff now, but it still has slack. Im talking about a little over 1/4 of the motion of the pedal is completely loose. How do I go about adjusting the pedal?
PowerLeg
Jul 21, 2009 02:25 PM
autoxthis
Aug 21, 2008 11:19 PM
autoxthis
Aug 21, 2008 08:23 PM
Duck Sauce
Apr 13, 2008 09:30 PM
