Engine shifting rough
I just bought a daily driver integra about 2 days ago and im afraid i might have found why it sold cheap or maybe im just paranoid. Anyways when the car shifts (automatic) it seems to be a little rough. Im use to new cars and stick shift so i may just be trippin but it seems to be more notciable when i drive slow it seems to jark into the next gear. When i drive fast it all seems to shift smooth. Just the way it is or tranny problem? Anything i can check on my own to tell?
If I'm going very slow and it shifts it will shift a little hard because the RPM will drop hard with little acceleration. Try flushing out the transmission fluid a few times to see if it smooths it out.
Go ahead and purchase three quarts of Honda ATF and, assuming you have a B series, you will be using 2.5 quarts of it. This may help you out..or you could just go manual
natedawg173
Honda CR-V & Element
Dec 16, 2014 09:40 AM
if its not shifting into the next gear what is it doing then?
