Issues With Map Sensor Voltage
Old May 10, 2009 | 08:32 PM
BKKloppenborg's Avatar
Default Issues With Map Sensor Voltage
Hey guys, well finally figured out it wasn't my map sensor that was the issue with car. I replaced it 3 times still no luck.The check engine light says the Map sensor voltage is to low. I tested the Engine harness wires going into the map sensor. The 3 wires going to map sensor, only one is getting 5 volts, other two are getting 0.3. I was wondering if anyone has had this issue and the best way to fix it. Its drivng me fing crazy!
Benny Bao
Oct 14, 2014 11:47 AM
reddysol
Sep 8, 2007 10:57 AM
methos713
Jun 11, 2007 12:43 PM
