clutch/flywheel help
Old May 7, 2009 | 04:53 PM
mrccupid3's Avatar
New User
Default clutch/flywheel help
just installed ah fidanza flywheel and a act clutch. i have bleed the clutch slave cylinder a million and 1 times. with the car running i cant get into any gears. the fork is not traveling enough when i push in the clutch pedal. help anybody
Old May 7, 2009 | 05:10 PM
Targa250R's Avatar
be professional
Default Re: clutch/flywheel help
Why did you install a new clutch? What year? Mileage?
I suspect a faulty master or slave cylinder.
Old May 7, 2009 | 05:47 PM
IntegraCF21's Avatar
Sounds like you don't have any pressure in the clutch line. What I had to do to mine when I swapped in a manual tranny and started with no pressure at all in the line, I had to pump the fork by hand to finally get some pressure back since the clutch pedal wasn't moving it at all. So bleed it like normal, but pump the fork by hand instead of using the clutch pedal.
Old May 8, 2009 | 07:09 AM
mrccupid3's Avatar
New User
i built my engine so i upgraded the clutch and flywheel. there is some pressure but the clutch pedal feels very loose. i have to push it almost half way down before i feel any resistance. the rod from the slave cylinder is moving but not enough to move the fork to where it needs to be. about a 1/2 inch shy.
kaivorth
Honda Civic (2001 - 2005)
Apr 3, 2017 07:17 AM
blink_977
Jun 4, 2009 01:31 AM
ddtfrom626
May 6, 2009 10:02 AM
ej1vtec
13
Jun 10, 2006 01:33 PM
wunPOINTeight
20
Aug 2, 2005 06:17 AM
