ls vs. gsr shifter
ls vs. gsr shifter
are they the same? do all the integras use the double bend style shifter? im wanting a stock shifter to replace my short throw and want the double bend but a friend thought only the gsr had them. thanks.
Re: ls vs. gsr shifter
both should be the same, my 00' LS has a double bend shifter. But to make sure you should look up the part on the online acura oem catalog and see if they have the same part number.
http://www.acuraoemparts.com/delray/jsp/home.jsp
hope that helps
hope that helps
