How hard to switch engine harness?
Old Jul 17, 2009 | 01:32 PM
GsDAteg's Avatar
Default How hard to switch engine harness?
I'm looking at buying a 95' teg with a JDM B18B. The guy said when it was swapped he used the JDM harness so the car throws a code for the cat becuase I guess the jdm harness has a single wire cat instead of a 4 wire. So how big a deal is this? Easy to replace with a new harness? Or is there a way to just wire a 4 wire 02 sensor in place of the single wire and not throw a code?? I don't know much about cars and am wondering if this is a easy fix or not.
Old Jul 17, 2009 | 03:10 PM
ek-g6's Avatar
Default Re: How hard to switch engine harness?
Did he just use the engine bay harness or the whole cabin and ecu harness from the jdm motor? If just the engine bay harness then I would use the usdm harness, with the usdm ecu, and ur problem would be solved.
Old Jul 17, 2009 | 04:47 PM
GsDAteg's Avatar
I'm assuming just the engine harness. The car is a 95 GS that had a B18C swap in it but he took that out and put in a low JDM B18B swap. I guess he didn't have a the stock engine harness anymore and used the one that came with the JDM motor.
Old Jul 17, 2009 | 06:32 PM
ek-g6's Avatar
I would just use a b18b1 usdm engine harness.
migrod1
12
Jun 27, 2015 10:32 PM
hannslebo
12
Jun 4, 2009 12:24 PM
Jimmii
Apr 9, 2009 06:54 PM
ej1_jdm
Dec 5, 2005 01:11 PM
LostAndFound
May 11, 2004 05:17 PM
