which head studs to use
Old Jul 15, 2009 | 10:47 AM
young geezer's Avatar
Default which head studs to use
i have a gsr block and b16 head. i was wondering which head studs and head gasket to use. people have told me to use the gsr head studs and gsr gasket. is that correct.
Old Jul 15, 2009 | 11:47 AM
mouab18c1's Avatar
Default Re: which head studs to use
im thinking you would use the b16 since its a b16 head...
Old Jul 15, 2009 | 04:18 PM
ek-g6's Avatar
you need gsr, the itr and b16 has the same head casing, and itr uses longer headstuds because of the longer block. I dont think head gasket is a factor, b16s,b18cs, uses the same head gasket.
Old Jul 15, 2009 | 05:09 PM
stevenDAtegra's Avatar
GSR is correct. GSR and LS Blocks needs GSR headstuds no matter what VTEC head. I think the same goes with b20's but not too sure
Old Jul 15, 2009 | 05:50 PM
mouab18c1's Avatar
so you're sayin he needs gsr head studs with his gsr block and b16 head correct? talking about ls and b20's only confuses him more since it confused me...
Ruben19's Avatar
^ dude is right.
Old Jul 15, 2009 | 06:44 PM
ek-g6's Avatar
He need gsr head studs. Get the head studs meant for the block and not the head.
Old Jul 15, 2009 | 09:58 PM
Unless you do something like ls head with a GSR block then you need ls headstuds but who would do that lol
Old Jul 15, 2009 | 10:20 PM
mouab18c1's Avatar
funny!
Old Jul 15, 2009 | 10:21 PM
mouab18c1's Avatar
this does not apply for all setups...when doing ls vtec's you need studs for whichever head you are using..i did a b20vtec and i used gsr headstuds..not the b20..but why we debting..the OP's not even responding...
Old Jul 15, 2009 | 10:44 PM
funny!
I wish I had a dyno so I could put one together and try that out lol
I think you may have mis worded since you know what's going on. With all LS VTECs and B20 VTECs, you use GSR head studs no matter what VTEC head is used.
It's determined by how the heads are setup since ls head studs have a few longer ones than others because the head doesn't have all of the locations for the bolts at the same height. If you used LS head studs, a few would either be too long or too short, not sure which
Old Jul 15, 2009 | 11:30 PM
mouab18c1's Avatar
thats correct, i just read it..you use either one itr or gsr headstuds for ls/b20vtecs
Old Jul 16, 2009 | 12:11 AM
yeah, most people just buy the headstuds for a GSR instead of piecing them together and GSR and ITR should be the same studs
Old Jul 22, 2009 | 07:01 PM
ok so i got a stock gsr head studs and oem head gasket. now what torque spec do i use and can anyone link me to it that would be much appreciated. thanks
Old Jul 24, 2009 | 09:59 AM
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/faq-b-series-torque-specs-953151/
Start from the middle of the head and work your way out when tightening
rauber15
Sep 11, 2017 11:46 AM
95civic16
Apr 23, 2008 06:14 AM
delsoldrew
Jun 22, 2007 06:09 PM
blowme
May 24, 2005 05:37 PM
ScottEK
Dec 11, 2004 01:12 PM
