overheating help :(
Old Jul 16, 2009 | 10:58 PM
nrst89's Avatar
Default overheating help :(
i drive a four door ls and the other day on the freeway my car started overheating, pulled over and pushed it to a friends filled radiator up with water...then drove it back home to find out the top hose was split...so i replaced it...replaced the coolant and filled up the reservoir...drove around made a few little out of town trips until yesterday overheating again...i squeezed the hose and coolant came out from where the hose connects to the motor...what could it be? no leaks or anything on the radiator and the fan works...
Old Jul 16, 2009 | 11:02 PM
Ruben19's Avatar
Default Re: overheating help :(
air in the cooling system. need to bleed.
Old Jul 17, 2009 | 01:27 AM
NazVil86's Avatar
bleed it out like ruben said, is there a leak? when the car over heats is the water in the reservoir boiling like crazy? my ls was doing this a week after i bought it- i got pissed, i was ready to fork out the cash to replace all the lines, water pump, everything- buddy saw that the radiator cap was bad and not holding down the pressure so it would slowly escape out of the sides. its worth a try
Old Jul 17, 2009 | 06:21 AM
HondaTom87's Avatar
make sure that hose is on the motor tight... then bleed all the air out of the lines... if this doesnt solve the problem check the fans and the all the sensors... if they are all functioning properly then you probably need a new water pump
Old Jul 17, 2009 | 09:22 AM
carfanat1c's Avatar
That... just the fact you had to FILL UP your radiator means your losing coolant make sure everything is tight, secure, and not leaking whether you push on a hose or not.
Fill it up, bleed, then fill again if needed.
Coolant is escaping which means air is entering and air doesn't cool very well.
Old Jul 17, 2009 | 02:38 PM
nrst89's Avatar
how do i bleed the cooling system? im going to purchase a new radiator cap right now seeing as the one thats on it right now is a ebay mugen one lol...
Old Jul 17, 2009 | 02:39 PM
nrst89's Avatar
also somebody told me it could be my thermostat...
Old Jul 17, 2009 | 02:45 PM
DankEk's Avatar
New User
if it happens again, this might be a bit of assistance.
http://bestroadsideservice.com/?lacee
moncherris_em1
Honda Civic (2001 - 2005)
Mar 28, 2011 05:37 AM
greenlikematt
10
Jul 22, 2008 06:30 PM
I3ooS710
Mar 25, 2006 03:45 AM
animalchin32
Jul 8, 2005 06:35 PM
SolidSpruce
Oct 2, 2003 06:42 AM
