Check engine light?
Old Jul 15, 2009 | 07:08 PM
CUTTERSPOOL's Avatar
Default Check engine light?
I;m getting a headache from all these check engine light crap. I let auto zone read the codes up and it said misfire #2.
I changed the spark plugs, spark plugs wire, cap, and rotor. I Did an oil change and a value adjustment. I did a compression test that reads 185, 120, 160, 170. Could you be a bent value that giving me those numbers?
Old Jul 16, 2009 | 04:51 AM
Default Re: Check engine light?
I checked the codes again and it read misfire #2 and random misfire. Anyone?
Old Jul 16, 2009 | 05:00 AM
LoveMyDA9[b18c]'s Avatar
Well you defenetly wanna look into piston #2 cause there's is to big of a gap from 185 to 120 160 and 170 is not so bad bt where is ur compresion suppose to be at? Evr since the light came on have you notice any change in ur engines performance?
Old Jul 16, 2009 | 06:05 AM
The car had this problem when I bought it. When idle there is a little hestiation but it not noticable. The car drive great still with no sign or failure.
alfiler
Feb 16, 2009 11:55 PM
LSxVQ35
Sep 10, 2008 05:31 AM
EL'ation
Mar 10, 2006 02:32 PM
1CleanLS
Apr 9, 2005 07:39 PM
Copy Cat
Dec 25, 2004 03:14 PM
