Climate Control Illumination problem
Old Jul 13, 2009 | 05:35 PM
vulong's Avatar
New User
Default Climate Control Illumination problem
okay, so i change my stock climate control to the jdm climate control and the climate control does not illuminate everywhere, only the number lights up and sometime randomly the temp (hot/cold) bulb come on randomly. I check the bulb to see if they were fine and they were so im thinking could it be some bad wiring?
Old Jul 13, 2009 | 10:35 PM
ShinsenTuner's Avatar
No Jodas
Default Re: Climate Control Illumination problem
Not bad wiring. The bulbs are just old and aren't making a correct connection.
Old Jul 14, 2009 | 09:12 AM
XslickwhitetegX's Avatar
need new bulbs to solve the problem part number is 34354-SB0-003, takes 4 bulbs
I had to do samething when i installed my itr climate control
Old Jul 14, 2009 | 09:20 AM
iH8RICERZ's Avatar
if you still have your old climate control, try switching your old bulbs to your new climate control and see if that does the trick. I've ran into the same problem and went through about 4 climate controls over the years....lol
Old Jul 14, 2009 | 04:34 PM
vulong's Avatar
New User
So i tried switching the bulb that was working into the ones that are not working and now none of them work
BOTAN01
Dec 20, 2007 11:15 AM
BOTAN01
Lighting
Dec 19, 2007 07:07 AM
eluam
Dec 2, 2007 10:55 AM
black-hatch
May 3, 2003 05:30 PM
