problem with the a/c
Old Jul 16, 2009 | 12:58 PM
MaRkO-Sparco's Avatar
New User
Default problem with the a/c
hi..i have a qestion my a/c doesnt cool to well the air is kind of warm...i think that is the expansion valve but i dont know were is...somebody sed me that is inside the dash panel...have any idea???
Old Jul 16, 2009 | 01:22 PM
red98integra's Avatar
Default Re: problem with the a/c
I think you just need to have the AC recharged...thats the way mine is...I really need to get around to doing that
Old Jul 16, 2009 | 01:27 PM
New User
i recarged the a/c twice and still the same warm air...
Old Jul 16, 2009 | 02:24 PM
ElementzofR's Avatar
bad compressor maybe.
Old Jul 16, 2009 | 06:14 PM
94LS90RS's Avatar
The expansion valve is located next to the evaporator core under your glove box. If the expansion valve isn't working it usually sticks open or closed, I would say not a common problem unless its really old. If its stuck closed, then it freezes up and you can visually see this. If its open, the system never gets that cold but still half way works. If you have A/C gauges then check to make sure the system is correctly filled. If you don't have gauges I would take it to some shop that does. The home charge kits are not designed if your system has completely leaked out. About how much did you charge the system, one can = 1lb? Sorry for the long post I have become quite an A/C nerd.
Old Jul 16, 2009 | 10:09 PM
^^^ hey since you know so much about a/c, can you tell me why my compressor makes this humming noise when i accelerate? i mean its works fine. nice and cold. just makes that humming noise.
Old Jul 17, 2009 | 05:03 AM
94LS90RS's Avatar
Element,
Could you take a video/sound clip so I could get a better idea. If its coming from the compressor it could be anything from the belt or the compressor starting to go bad.
Old Jul 17, 2009 | 07:52 AM
worx's Avatar
yes i think something is going on with mine was working good until yesterday it was 105 im driving trying to stay cool then i smell this burn smell like elitrical so i stocp and check it out its coming from the compressor
iv
14
Aug 11, 2014 10:56 PM
Jody Sherburn
Jul 9, 2011 07:16 AM
MrMug3n
Oct 12, 2009 06:55 AM
anthrax718
Jul 4, 2009 09:43 PM
Mike813
Sep 5, 2003 11:25 AM
