Fuel pump removal help
Re: Fuel pump removal help
Replacement
Do not smoke while working on fuel system,
Keep open flames away from your work area.
1. Remove the rear seat (see section 20) (20) (Hatchback: Remove the spare tire lid and the protective cover)
2. Remove the access panel.
3. Disconnect the 2P connector from the fuel pump.
Remove the fuel pump mounting nuts.
Remove the fuel pump from the fuel tank.
install parts in the reverse order of removal.
did you remove 3 bolts from access panel and 6 from the fuel pump assembly?
edit: http://www.team-integra.net/sections...?ArticleID=391
Replacement
and whats strange is that i see from the thread where they would be and it seems like mines completely different
HEY, im having the same problem on my 93. i have the new pump, but it looks nothing like what im seeing under the access panel, the wires connections look the same, but that is about it.
lol bump for us, its strange isnt it? my friends teg looked different and was much easier. im sure someone here knows.....
yeah, you would think. there are two differient connections on the new pump harness right? one goes to the plug in your pix and the other connects to the main harness. its is almost like what we are seeing under the inspection cover is the sending unit. but why would they be in differeint locations??? This is confusing
IM tempted to take a damn cutoff wheel to the floor...
here's the fuel tank removal diagram from the acura service manual. from the look of this, it's under the seat, but you can see there are two access panels. maybe you guys aren't pulling enough crap out to find the pump? either way, check out the other access panel, we could be in for a surprise.
G/L
This picture you have here is your fuel gauge sending unit. The fuel pump in under the rear seat. Remove the rear seat by pulling (2) clips on each side of the backrests, and (1) 10mm bolt. Then the rear seat will pop off and you will see an access cover similar to the one above, but bigger. Remove that and you'll figure it our from there.
G/L
G/L
He didnt say if it was a DA or a DC...
If it is a DA then you have to pull the tank to get to the pump, it cannot be accessed from under the seat, only the sneding unit is there.
As for MR 89EFLS i hope you got to it as well its not hard at all once you find the right access panel lol
New User
i have an 87 prelude si 2.0
how can i tell if the fuel pump is under the seat or on top of the fuel tank
i`m assuming its the fuel pump thats needs to be replaced as when i turn the ignition on it continously gargles and hums.
birds_sol_94
14
08-10-2004 01:15 PM
