Prelude Injectors and Fmu
A friend told me that I can change my stock injectors for 97 prelude injectors, and with my setup, jdm second gen b16, t3/t4 b turbo, fmu, missing link, I can boost up to 10 psi. He did this on one of his cars. What do you guys think? I don't want to run mad power, but enough to be a little fast!! Thanks
Re: Prelude Injectors and Fmu (Autobot_Killer)
The 97+ prelude injectors are rated at 270cc, not much different from the 250cc you have in there now. With a 12:1 fmu, your existing 250cc should be more than enough at 10psi of boost
Re: Prelude Injectors and Fmu (VIMPORT.COM)
... i think it is 240cc and 290cc... so switching to prelude injectors increases flow by ~20%... i'd say it would help... i dont know about 10 psi... but, if you are going to push it that hard i would definitely get to the dyno to check a/f... personally, i would look into better fuel management like hondata instead of risking it... hope this helps...
spoon95eg
12-19-2005 06:15 PM
