turbine housing trims? stage or numbers?
I got this from http://www.turbonetics.com . I want to get an GT30 ball bearing turbo T3/T04e .63 a/r 84 trim with 60 a/r 52 trim *50lph* from cheapturbos.com . But what is stage II, III and standard trim? IS this a new (seperate) spec or is it just the same like 84trim on the hot side? If it is bigger nummer = more lag with more top end right?
AR TRIM
.63 STANDARD
.63 STAGE II
.63 STAGE III
btw: I want to know the exact specs of my DRAG III turbo I have, I only know it has .63 ar and .54 ar T3/T04e hybrid, but what are the trims and the stages of this turbo?
AR TRIM
.63 STANDARD
.63 STAGE II
.63 STAGE III
Re: turbine housing trims? stage or numbers? (austrian type-R)
The stage II and Stage III come from the T31 family of turbines.
T31 family of turbines:
.69 trim= stage 2 turbine
.76 trim = Stage 3 turbine.
The stage 5 comes from a different family, the T350.
.76 Trim T350 = Stage IV.
Hope this helps.
art
Hope this helps.
art
Re: turbine housing trims? stage or numbers? (Arturbo)
and what is 84 trim? So I hav now on the standard DRAG Turbo 76 or 69 trim? hehe you was fsater. but my ar on the compressor housing says .54.
60 ar housing?! Are you sure? what lph does the standard drag turbo has?
so this turbo is smaller with T04e than I have now? http://store.yahoo.com/cheapturbo/newgargtt3.html
thanks man, you are always helpful
Every time I know more it is getting harder to deceide
what is better: to have an .82 a/r and an T04e (52 or 56 trim) or an .63 a/r with an T04s housing (52 or 56 trim). Which style of those 4 will spool better and which one will responde better..(all turbos with that 84 trim)...can you list them up 1 - 4?
Greyout
08-07-2003 08:15 AM
