Bolt stuck in turbo!
Old Aug 6, 2003 | 07:16 PM
Lost Type R's Avatar
Default Bolt stuck in turbo!
Well guys worse came to worse... I snapped one of the bolts in half and one half is stuck in the turbo! Installing downpipes is a bitch and now im not sure if i have to get the bolt machined off my turbo. I heard something about a v-band or some sort... does anyone have any ideas?
Thanks.
Old Aug 6, 2003 | 07:30 PM
Jared's Avatar
Default Re: Bolt stuck in turbo! (Lost Type R)
got a picture?
Old Aug 6, 2003 | 07:32 PM
Default Re: Bolt stuck in turbo! (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">got a picture?</TD></TR></TABLE>
hold up lemme get a picture of it now.
Old Aug 6, 2003 | 07:37 PM
inspyral's Avatar
Go to the hardware store and get an extractor set/Easy-out, and an appropriate sized drill bit and take it out.
Old Aug 6, 2003 | 07:59 PM
Default Re: (inspyral)
Old Aug 6, 2003 | 08:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Go to the hardware store and get an extractor set/Easy-out, and an appropriate sized drill bit and take it out.</TD></TR></TABLE>
i wonder how that works... is it really "easy out"? sounds like an idea... ill look into that.. any other ideas out there though? dont wanna spend a couple of bills buying a new turbo... Anyone familiar with the v-band?
Old Aug 6, 2003 | 08:07 PM
CD8's Avatar
CD8
Default Re: (Lost Type R)
the easy out works by drilling into the bolt, then you have an appropriately sized tap that you screw down into the hole you drilled. then you used that to remove the bolt. easy.
Old Aug 6, 2003 | 08:08 PM
Default Re: (CD8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD8 &raquo;</TD></TR><TR><TD CLASS="quote">the easy out works by drilling into the bolt, then you have an appropriately sized tap that you screw down into the hole you drilled. then you used that to remove the bolt. easy. </TD></TR></TABLE>
whoa now thats easy.. ill goto the hardware store tomorrow..
Thanks for your replies.
Old Aug 6, 2003 | 08:22 PM
liam821's Avatar
25 Year Member
easyout has saved my *** a few times!
liam
Old Aug 6, 2003 | 08:42 PM
importboi22's Avatar
Default Re: (liam821)
yep just easy out it... super easy had to do on an oil pan once... also if you cant get it with an easy out and enuff of the bolt is sticking out try a pair of big vise grips but... i dunno there isnt much of the turbo sticking out there dre... good luck if you need help lemme know
Old Aug 6, 2003 | 09:38 PM
Lei Siew Long's Avatar
something similar happened to my friend's car recently. he broke off the stud on the head to mount the exhaust manifold. we bought a bolt extractor and a drill bit that is the same size.
center punched the broken stud, drilled a hole on the stud, and extracted it out with the bolt extracting bit.
Old Aug 6, 2003 | 10:02 PM
DLOTYPER's Avatar
Default Re: Bolt stuck in turbo! (Hatch4urSnatch)
i did that some ****, i didnt have an easy out, so i removes the turbo and exhaust mani, then i took a dremel and cut across the broken bolt on the exhaust housing, tryin not to notch the housing,,,(use a small *** whell, or a worn wheel will do) then i simply used a flathead impact driver and got it out,,,,,,,viola!!!!! that **** really worked!! so give that a shot, i thought the easy out kit was pricey, thats why i did that,,,,,,,,good luck
Old Aug 6, 2003 | 10:04 PM
Tofurky's Avatar
yes, an easy out worked for me as well.
once in an old turbo, and again when i broke off a cam holder bolt.
just be sure to cover up the surrounding area with paper towels, or something to keep the shreds out of the turbo itself.
Old Aug 6, 2003 | 10:23 PM
Default Re: Bolt stuck in turbo! (Tofurky)
is an easy out the same as the bolt extracting bit? or are they two different things?
Old Aug 7, 2003 | 02:15 AM
SOFLSOL's Avatar
same thing.
Old Aug 7, 2003 | 07:23 AM
Bailhatch's Avatar
Default Re: (SOFLSOL)
If the bolt broke off because it is seized you may have to heat it up to make the easyout useful. The last thing you want is a broken bolt with a broken easyout in the middle of it.
Old Aug 7, 2003 | 09:11 AM
01ITR#700's Avatar
Default Re: (Bailhatch)
FWIW the guy that does my welding sometime actually welds a bolt onto broken bolts like that. Then he simply turns the new bolt and voila, it unscrews the borken bolt as well.
Mark
Old Aug 7, 2003 | 03:37 PM
GSRswapandslow
Guest
Posts: n/a
but if the weld laps over...you're fucked
and an easy out...BE CAREFUL. Tooled steel is brittle...but SUPER HARD. Drilling through an easy out....is NOT easy.
Old Aug 7, 2003 | 05:34 PM
spoolinlude's Avatar
I live under a rock
Default Re: (GSRswapandbanned)
chuck it in a lathe or drill press even and drill that thing out, then get some nice arp bolts to put back in there.......... i went with a nut/bolt so they cant really break off inside ne thing anymore
maintain
May 15, 2008 08:34 PM
EMFinite
Apr 26, 2007 04:47 PM
HCJDM1
Feb 2, 2007 06:09 PM
GDM Z28
Dec 27, 2003 06:48 PM
HuskerHybrid
Jul 9, 2003 10:22 PM
