CRX Turbo Radiator, I'm Screwed
I'm having a lot of trouble figuring out what to use for a radiator on my B16 Turbo CRX. I checked both my local junkyards, neither has the rare dodge neon half sized radiator. I checked on some neon message boards and even they have a hard time finding them. So my other choice was an EG radiator, I tried it and there is no way to make it fit even with frame modification. What are my other options? If I go aftermarket I need something as cheap as possible, please help.
Re: CRX Turbo Radiator, I'm Screwed (beta13)
well, place racing makes the front crossmeber that allows a 93 civic half radiator to fit like stock, butt is like $300 or so. You are having clearence issues with a T3? were does the HCP mounts place the motor in respect to HASports? I know with my HASports, they move the motor back far enoungh(TPS 1 1/2" from firewall) so that i could run a T3/T04E and a stock radiator without clearence problems. Its tight but it works. I had place racing mounts but there was no way the turbo would fit, so i had to swap them out. Hope this helps...
Brett
Brett
Re: CRX Turbo Radiator, I'm Screwed (yellowhonda88)
Well it's a homemade manifold and I should of put the turbo closer to the block and took off the internal wastegate, then I could of used the stock radiator. What is the cheapest aftermarket radiator?
check this out.....
https://honda-tech.com/zerothread?id=538221
Thats my car, let me know if u have any questions
I think I found the perfect radiator, it's the same height as the CRX, 1/2 inch smaller in width than the EG, and it's a "Two Row All Metal". It's out of a 96 Suzuki Swift and accepts the same size lines as the CRX.
Core Size: 12-13/16 X 12-15/16 X 1-5/16
Inlet Header: 13-9/16 X 1-9/16
Outlet Header: 13-9/16 X 1-9/16
Inlet Connection: TOP 1-1/8 DRIVERS SIDE
Outlet Connection: BOTTOM 1-1/8 DRIVERS SIDE
Transmission Oil Cooler: 7-7/8
Engine Oil Cooler: NONE
Mounting:
Notes: TWO ROW, ALL METAL
Mounting:
I have a 91 crx with a b16. turbocharged with a revhard kit. I know what you mean about clearance problems. when i was on the dyno my turbo punched a hole in my radiator. So for a cheap fix i took it to a radiator shop and had them weld the radiator floots closed were the turbo was rubbing. that way there is no coolant running thru that section of the radiator. I have had no problem with over heating and it cost a total of 20.00$ hope this helps
Re: CRX Turbo Radiator, I'm Screwed (trickmurf)
before my car was stolen i had PWR make me a custom piece.it had the same dimensions as a 5th gen rad.the exception being the dimesnsions were switched so it could clear my hood.no coolant issues whatsoever.i think the caore was about 2.6 inches thick.email me for a pic
Re: CRX Turbo Radiator, I'm Screwed (civbeater90)
i have a b20b turbo with my stock rad using the inline pro mani... just get someone real real real good to make your piping and it all works
Re: CRX Turbo Radiator, I'm Screwed (b20turboic)
I'm just going to order a PWR, you really can't go wrong with one. I had to design my manifold with the turbo further away from the block because of the internal wastegate.
