Can i run bigger injectors on a fmu?
Old 08-06-2003, 11:20 AM
SpdFrk's Avatar
Default Can i run bigger injectors on a fmu?
Would i be able to run bigger injectors on a fmu or will i have to get a safc to control the injectors?
Also Im currently running 2 1/4inch downpipes with a high-flow cat, could i run 10 psi with the 2 1/4 down pipes or is to small to run 10 pounds.
Old 08-06-2003, 11:42 AM
kpt4321's Avatar
This sems to be a weekly question around here.
The whole point of a FMU is to allow you to get enough fuel for a turbo, while maintaining stock injectors.
To use any injector with a larger flow rate, you will need fuel control.
2.25 will probably be fine. Bigger is always better, but it's "good enough."
Old 08-06-2003, 12:58 PM
New User
jinxproof99's Avatar
Default Re: (kpt4321)
you can run 440's with a fmu, but you will need the afc to make it idle and be able to tune the fuel well enough to run.
Old 08-08-2003, 06:16 AM
Fatty_1775's Avatar
Default Re: (jinxproof99)
I heard and read that you can run 97 prelude injectors with an fmu (on a b16 that is) Correct me if im wrong
Modified by Autobot_Killer at 4:30 PM 8/8/2003
Old 08-08-2003, 07:42 AM
b18b98's Avatar
Default Re: (Autobot_Killer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autobot_Killer &raquo;</TD></TR><TR><TD CLASS="quote">I heard and read that you can run 97 prelude injectors with an fmu (on a b16 that is) Correct me if im wrong
Modified by Autobot_Killer at 4:30 PM 8/8/2003</TD></TR></TABLE>
Yes you can. Either a 12:1 or a 10:1 would be good with those injectors.
Old 08-08-2003, 09:23 AM
autoEXturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 &raquo;</TD></TR><TR><TD CLASS="quote">you can run 440's with a fmu, but you will need the afc to make it idle and be able to tune the fuel well enough to run.</TD></TR></TABLE>
This is what i used to run, made good power and ran excellent times.
Old 08-08-2003, 07:16 PM
spooned out's Avatar
if you use 310cc with 10:1 fmu will it be running to rich? If so will a FPR help lean it out?
spoon95eg
12-19-2005 06:15 PM
IDriveHonda
09-23-2004 09:50 PM
D16SI
02-05-2003 06:10 PM
Herminator
02-01-2003 08:47 AM
freeplay
12-01-2002 09:41 AM
Quick Reply: Can i run bigger injectors on a fmu?
