How do you guys get to the dyno with your setup?
Old Aug 6, 2003 | 10:40 AM
5thgencivic's Avatar
Default How do you guys get to the dyno with your setup?
If you are going to the dyno to get say hondata installed and tuned, how do you not boost? On an internal gate system you can rig the gate open, but what about with a tial gate? Don't want to undue the charge pipes and overspin the turbo. what do you do? Thanks.
Old Aug 6, 2003 | 10:45 AM
R6Elmo's Avatar
Default Re: How do you guys get to the dyno with your setup? (5thgencivic)
can't you drive without boosting? Unless you have a very responsive turbo or nice hilly drives, you should be fine.
Old Aug 6, 2003 | 10:53 AM
Mr. Softee's Avatar
Default Re: How do you guys get to the dyno with your setup? (R6Elmo)
its quite easy to drive without boosting
Old Aug 6, 2003 | 11:10 AM
Default Re: How do you guys get to the dyno with your setup? (94goldjungsr)
not if you have major hills on the way there.. So everybody just drives in vacuum then?
Old Aug 6, 2003 | 11:15 AM
Spunkster's Avatar
You are aware that the gas pedal (throttle) is a variable position device, which has more than on and off?
Just drive like your grandmother.
Old Aug 6, 2003 | 12:19 PM
mike1114's Avatar
Default Re: How do you guys get to the dyno with your setup? (Spunkster)
you can take out the spring inside the wastegate, then you will not see any boost.
Old Aug 6, 2003 | 12:57 PM
Default Re: How do you guys get to the dyno with your setup? (mike1114)
ok, thanks.
Old Aug 6, 2003 | 09:22 PM
Pengo's Avatar
uh, i've driven for days without hitting boost, hills or not. as long as your foot doesnt weigh 10lbs and you select ur gears properly you will be fine. and keep your eye on the boost/vac gauge if your not used to driving easy
Jan 22, 2008 07:42 AM
Synapse
Oct 5, 2007 01:12 PM
turbosol18
Sep 7, 2007 11:45 AM
siis2fast
Aug 28, 2005 08:21 PM
brian b
Aug 22, 2002 05:07 PM
