map sensor for supercharger
Old Aug 6, 2003 | 06:31 AM
deez92's Avatar
Default map sensor for supercharger
can someone please tell me where you relocated your map sensor too? and a pic would be alsome. thanks dee sorry this is for a jackson blower on a gsr.
Old Aug 6, 2003 | 08:12 PM
deez92's Avatar
Default Re: map sensor for supercharger (deez92)
anyone?
Old Aug 7, 2003 | 05:10 AM
RacerXI's Avatar
this is my b16a2 setup. I mounted my map at the end of where i had my boost guage with a small piece of silicone hose. HTH.
Old Aug 7, 2003 | 06:04 AM
deez92's Avatar
Default Re: map sensor for supercharger (RacerXI)
thanks, anyone else?
Old Aug 7, 2003 | 07:43 AM
jabroni95gsr's Avatar
i have hondata, so i had to plug the map sensor on the tb and i just moved it to the mani. you can see pics in my sig under install.
Old Aug 7, 2003 | 07:47 AM
92sleepR's Avatar
New User
Don't have a picture for you but on my B18C1 JRSC manifold there is a flat, machined spot on the pasenger side, top of the manifold, above the TB that seems designed for this purpose. I drilled a center hole for the MAP sensor nipple and then scribed the location of the mounting holes with the MAP sensor in place. Then I just drilled the mounting holes and tapped them for 4mm bolts. Works like a charm and looks pratically stock.
Uhhhh, needless to say, don't drill into your intake manifold while its installed on the car or you WILL get metal shavings into the engine. an alternative would be to machine a block of aluminum to mount the MAP sensor to the firewall and just run a regular vacuum line to it. Get creative it's amazing what you can do with a little aluminum bar stock, a drill press, and a few thread taps.
P.S. that picture above shows the spot on the manifold that I was talking about. Now that I remember, It isn't machined but I didn't need that spot to mount the throttle cable bracket so I just filed it as flat as possible using a fine tooth flat file.
Mike
Old Aug 7, 2003 | 08:51 AM
Spunkster's Avatar
I just used the Map relocator from Jackson Racing. It's a clean install and very easy as well.
Old Aug 7, 2003 | 09:05 AM
Muad'Dib's Avatar
Corr Performance Pilot
Mine looks something similar to this
and my TB section is plugged up something like this..
Old Aug 7, 2003 | 10:18 PM
deez92's Avatar
Default Re: (MouhadIb)
thanks for all the help guys
Old Aug 7, 2003 | 11:07 PM
VaporTrail's Avatar
New User
Default Re: (deez92)
Dee, just position it anywhere that is AFTER the blower. Any vaccum/boost source will do. If you need help just call me mang I'll help ya out
Old Aug 8, 2003 | 07:37 AM
deez92's Avatar
Default Re: (VaporTrail)
thanks john, if i can't get it right i'll stop by your shop.
allnaturalb16
Oct 19, 2007 10:14 PM
EJ8 GSR-T
Mar 29, 2007 06:48 PM
1.8T_EG
May 12, 2003 09:58 PM
