Sohc...5-7 psi... FMU Setup or AFC Setup ?
I know the dangers of the FMU setup on stock injectors, but at such low boost (5-7psi), with 310 injectors + FMU would work, but so would 440s + Hack.
But since the hack has it's issues (some hesitation, advanced timing in the low end) I am wondering if the FMU setup (w/ btm/link) would be better at that boost.
Any opinions ?
Any opinions ?
New User
Re: Sohc...5-7 psi... FMU Setup or AFC Setup ? (X2BOARD)
hesitation? if u mean bucking then ya... just learn to drive around it ...
my afc hack = smooth transition in and out of boost. pretty easy to setup. cheap and reliable
my vote is biased since ive only tried the hack . but it gets a
Re: Sohc...5-7 psi... FMU Setup or AFC Setup ? (psileepR)
the afc is a great alternative to fmu and check valves...i dynoed my car and with the fmu and hack and the a/f was much smoother and power much linear...
Re: Sohc...5-7 psi... FMU Setup or AFC Setup ? (eg6turbo)
okay im running a fmu and 255 holley intank fuel pump and missing link. now i wanna run 6 psi and its currently at 5psi.... will my fuel setup handle it or should i do the hack?
Re: (pip9)
for stock injectors and 6-7 psi is fine with the fmu setup...and with my vafc hack and the btm...i dont have any bogging, hesitating or hard starts....just pulls hard to red line....it take a whiel to tune on the dyno to get all the points set correctly....also...most setup arnt linear like i thot...most people say this:
my old settings...
1k -40%
2k-4k -38%
4k-5k -37%
5k-7k -35%
7k-8k -33%
my tuned settings
1k -23%
2k-3k -38%
3k-4k -36%
4k-5.5k -31% (when vtec kicks in)
5.5k-6k -34%
6k-8k -32%
after all this it gave me about a 12.2 a/f raito flat thru the rpm band which was really nice....i made 180 whp when it was tuned and 202 whp untuned....and if u were wondeing why i lost 20whp....it was 33 degrees hotter when i was tuning it then when i wasnt tuned....67 degrees compared to 100...if i came back on a nice and cool day i wouldve made 200+...but i just wanted my **** tuned....afc hack works very well especially for a max boost of about 11...anything more u would want a hondata....as u can see my settings were way off and i was running very very very lean when vtec hit....dropping it to -31 from -37 made a huge power increase....ill have my dyno sheet scaned up in the near future
my old settings...
1k -40%
2k-4k -38%
4k-5k -37%
5k-7k -35%
7k-8k -33%
my tuned settings
1k -23%
2k-3k -38%
3k-4k -36%
5.5k-6k -34%
6k-8k -32%
Re: (spooned out)
I'll recommend the s-afc w/450cc route.
I'm swapping over this weekend from a FMU setup. The problem with the FMU is that it isn't very tunable. One disc will run you a little lean with detonation and the next disc will have you wayyy too rich. With the s-afc you can tune to very close specs.
Just my $.02 ...
Just my $.02 ...
Re: (redteg87)
afc hack + dsm 450's + either btm or lower your base timing to like 15 dgrees so when it advances it doesnt advance it as far....and i would recommend a fuel pump also.....
Trav
Trav
The FMU isnt as bad as all you guys make it out to be. Running low boost like he plans on doing is fine with FMU and 310's....its the same thing i do on my GSR and it works perfectly. Running boost over 10 you should get the afc and larger injectors.
Re: (steroidguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steroidguy »</TD></TR><TR><TD CLASS="quote">The FMU isnt as bad as all you guys make it out to be. Running low boost like he plans on doing is fine with FMU and 310's....its the same thing i do on my GSR and it works perfectly. Running boost over 10 you should get the afc and larger injectors.
I would only run under 7psi on the FMU setup (I have run an FMU setup before)... beyond that... I'd definitely go hack... but I don't plan to go over 7psi right now.
As far as disc ratio... Vortec recommends a 6:1 for 30-37lb injectors, which is the recal kit I'd get for 310's. (Plus a fuel pump, of course)
Let me pose this question: If both setups cost you the same $$, would you rather hack or FMU for the intended boost level ?
Re: (X2BOARD)
If you do run the FMU, don't forget the inline pump or at the very least, a hi-pressure intank. Then there's the fact that you'll still want an AFC to fine tune it.. or you can just spend the same $$ and get the hack from the begining..
Re: (steroidguy)
I've run it. The problem is the lack of fine tunability. It is great for street/daily driving but sucks at the track where higher boost and greater tunability is a must.
Re: (RexSiT3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexSiT3 »</TD></TR><TR><TD CLASS="quote">afc hack + dsm 450's + either btm or lower your base timing
what i did before. on my b16a only my timing was stock for about 2 months at 8psi. no problems at all. my new setup in a civic dsm450cc injectors, safc or vafc which ever i can find cheaper. no fuel pump needed. also u can retard your timing by using your dizzy. just get a timing light and rotate it towards your car.
Re: (bmcc72)
Ok, well I already HAVE the following:
*DSM 450 injectors/resistor box
*FMU
I will need for an FMU setup: 310's ($170-$250), Inline pump ($150-$200), Recal kit ($30)
FMU Totaling $350-$480
For an AFC setup... all I'd need is: Clean injectors ($100), VAFC($150-$230)
AFC Totaling $250-$330
Well guys... retarded base timing...btm...w/e I use... I think I'm sold on the hack in my situation. Thanks for the input thus far !
*FMU
boostincoupe
09-11-2003 12:53 PM
