ok I'm ready to put my "piece" together.............
HELLO,GOOD MORNIN'
what little things do i need like which gaskets?
Or can some parts go metal to metal.
Manifold--->turbine
turbine--->down pipe. and other little things you can think of.
Antwaine
Manifold--->turbine
Antwaine
Re: ok I'm ready to put my "piece" together............. (HybridcivicLS-T)
only gakset you should need would be a wastegate gasket, get the turbonetics one with the metal fire ring or else you'll be replacing them every few weeks like I was.
they are $10 jotech should have em.
HELLO,GOOD MORNIN'
Re: ok I'm ready to put my "piece" together............. (Foozball26)
thanks Matt. Wait till you see the shiznit i got. I didn't half step. all good quailty at the best prices.
sweet man, what all do you have left to get and when are you putting all of it in?
btw I got some new toys as well.
No more overheating for my engine or me (new condenser since my dumptube put a hole in the old one, A/C here I come.)
I crushed about 2-3 wastegate gaskets, then i decided to just not run one, no leaks at all. Good to hear youre finally done, My install is next weekend, so tally up two more Turbo hondas to the Texas list
Other side of town near Lake ray hubbard
I may need to install @ Direp's house because of downpipe issues.
HELLO,GOOD MORNIN'
Re: ok I'm ready to put my "piece" together............. (quikB18B)
I hope everything works out good for your project. Are you running hondata? IM me please.
I went through 2 Tial gaskets before I stuck some copper sealant gasket. I also used in on my downpipe. Works well.
well the tial gaskets are crap, all you do is burn them up and that cause an exhuast leak.
The metal ring gaskets are where the money is, doesn't allow the gasket to be burned up, think about it this way...what are headgaskets made from? same stuff.
metal to metal only works well if both surfaces are perfectly flat and just hope it doesn't warp or anything like that.
Ill stick with my gasket, I blew 2 tial gaskets in 2 weeks then got the turbonetics one and haven't had a problem in 6 + months of races and spirited driving.
W O T
11-13-2005 11:58 PM
lucas569
09-02-2002 01:07 AM
GSRwBOOST
08-28-2001 02:54 PM
