Vac leak from injector seals?
Old Aug 8, 2003 | 08:40 AM
SOFLSOL's Avatar
Default Vac leak from injector seals?
What are the symptoms of this?
Old Aug 8, 2003 | 11:47 AM
rioninja's Avatar
Default Re: Vac leak from injector seals? (SOFLSOL)
same symptoms of having a vac leak anywhere else.
Old Aug 8, 2003 | 02:12 PM
SOFLSOL's Avatar
Default Re: Vac leak from injector seals? (rioninja)
Ok. Because I remember hearing it makes you hit off the rev limiter when you start up heh.
Old Aug 8, 2003 | 02:18 PM
NateTEG95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOFLSOL &raquo;</TD></TR><TR><TD CLASS="quote">Ok. Because I remember hearing it makes you hit off the rev limiter when you start up heh.</TD></TR></TABLE>
That's pretty much true of any vacuum leak so long as it's big enough. For something that big.. I'd check to make sure you used a throttle body gasket
rookshot06
Mar 17, 2008 03:01 PM
TheTealHatch
Nov 7, 2007 04:10 PM
GetawayInMoscow
Nov 21, 2006 07:57 AM
importtuner07
Aug 10, 2006 10:07 AM
J337_UNIT
May 1, 2003 05:40 PM
