Boost/Compression
Old Aug 6, 2003 | 01:09 AM
TurboEKd16z6's Avatar
Default Boost/Compression
I have a d16z6 block, sleeved by Golden Eagle, stock crank, Eagle rods, Ferrea valves, springs and retainers..I am going with a 79mm bore.
My question here is..could I safely run 25 to 30psi on 9.8:1 pistons (arias or ross more than likely) with proper tunning, adiquit fuel and spark?
Old Aug 6, 2003 | 01:19 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Boost/Compression (TurboEKd16z6)
How much horsepower are you wanting?
From the c/r and amount of boost you are wanting to run I am not sure if the amount will even be necessary. What trim turbo are you planning on running with this?
Old Aug 6, 2003 | 01:28 AM
Default Re: Boost/Compression (INVALID)
The turbo is a t3/t4 w/ a .50 trim. I am looking to make 400+ hp...basiclly wanting to squeeze everything I can out of the little d16 I can.
Old Aug 6, 2003 | 02:01 AM
h22 ef's Avatar
why are you going with such a small bore, 79mm bore makes it a 1.5
Old Aug 6, 2003 | 02:28 AM
Default Re: Boost/Compression (h22 ef)
Correct me if I am wrong but stock bore is 75mm on the d16's. A 79mm bore with a 90mm stroke (stock stroke) would make it around a 1.76L
Modified by TurboEKd16z6 at 11:57 AM 8/6/2003
Old Aug 6, 2003 | 02:43 AM
h22 ef's Avatar
sorry i'm retarded, thinking b16
Old Aug 6, 2003 | 02:59 AM
It happens, we all make mistakes.
Old Aug 6, 2003 | 08:06 AM
Afternoon bump..!
Old Aug 6, 2003 | 09:43 AM
Pelican's Avatar
I dunno if a smaller T3T4 can sqeeze two bar without getting really hot and just spinning at like 250,000 RPMs.
Is this a street car?
25 to 30psi pretty hefty goal. I'd stick with 1 bar max and pull all the HP you can from that level. You can get 400+ without boosting 2 bar. But do it in steps.
Old Aug 6, 2003 | 03:00 PM
stevey's Avatar
Think there are going to be any piston/valve clearence problems? 9.8:1, milled head, block decked, your cam..
Old Aug 6, 2003 | 06:34 PM
Default Re: (s7e)
^ditto^
Old Aug 7, 2003 | 11:33 AM
Default Re: (TurboEKd16z6)
Old Aug 7, 2003 | 11:37 AM
lazerus's Avatar
i hope you mean that amount of boost on race gas. You should be able to meet your goal with that compression ratio, and turbocharger at sea level.
If my memory serves me right, i think 79mm might be a little scary for high boost apps, but dont take my word for it, i dont even own a honda
you probably wont get away with much more than 10 lbs of boost on pump gas, just so ya know :-)
Old Aug 7, 2003 | 12:28 PM
Default Re: (lazerus)
I was told by Golden Eagle that 79mm was as far as you could safely go.
LilCivic04
May 31, 2005 09:12 AM
LilCivic04
Feb 1, 2005 06:04 PM
91DroppedHatch
Nov 10, 2004 09:00 AM
sk8phaze
Feb 16, 2003 08:55 PM
00ITR #543
Nov 23, 2001 04:29 PM
