??? b16 and d16 rod bearings the same ???
Old Aug 7, 2003 | 08:38 PM
Neukin's Avatar
Default ??? b16 and d16 rod bearings the same ???
Heres a link for the original post, but iv had it up with no luck so i thought id try it here......... thanks
https://honda-tech.com/zerothread?id=580710
Old Aug 9, 2003 | 06:04 AM
Neukin's Avatar
Default Re: ??? b16 and d16 rod bearings the same ??? (toyosupr)
so
Old Aug 9, 2003 | 06:14 AM
earl's Avatar
I've used D16's in B18C's before by champhor cutting the edges of the bearing. I think there is a width difference between the b16 and the d16 bearing
Old Aug 9, 2003 | 06:43 AM
Neukin's Avatar
Default Re: ??? b16 and d16 rod bearings the same ??? (earl)
there is a 1mm difference. the b16 is wider then the d16 bearings. What do you mean by champhor cutting??
Old Aug 9, 2003 | 06:44 PM
earl's Avatar
Basically it is cutting the edge of the bearing that would rub against the radius of the crank journal. Kind of an angle cut to make up for the 1mm width difference
uboostivtec
Jul 1, 2010 02:28 PM
Importracer_001
Oct 31, 2004 11:35 AM
Diggins
Sep 15, 2004 10:55 PM
Neukin
Aug 6, 2003 04:28 AM
