help!!!! broken banjo bolt
Old Aug 8, 2003 | 11:33 AM
ek_will's Avatar
Default help!!!! broken banjo bolt
http://turbocivic.net/images/banjo.jpg the banjo bolt (far left on pic) its for the 92-95 greddy turbo kit while installing mines i tighten it too much and it broke now my car is sittin on the street please help if you know where i could find one i tried hardware stores pepboys home depot. i need one asap!!
any help is truly appreciated..
Old Aug 8, 2003 | 01:18 PM
Boosted_MRCSI's Avatar
Default Re: help!!!! broken banjo bolt (dash0n)
That really sucks don't it, the same thing happened to me when I was installing mines too. What I used was a 10mm x 1.25 Banjo Bolt from a local speed shop that was suppose to go on brake lines. The length of the bolt was shorter than the Greddy one and the holes on the bolt were smaller but it had a hole drilled from the bottom of the bolt as to Greddy's which only had a hole drilled on the side of the bolt.
We ended up using it and it works just fine with no problems yet. Also, try this link https://honda-tech.com/zerothread?id=319213, really helpful and if I would've found this link first I may have gone with the AeroQuip bolt. Unless you have a shop that carries AQ's products or you don't mind waiting and order the bolt from elsewhere, I'd try looking locally for the banjo bolt that I used. Hope you get it fixed soon man!
Old Aug 8, 2003 | 01:34 PM
SupaTeg's Avatar
I got mine fixed by a local shop man sorry
Old Aug 8, 2003 | 02:05 PM
scttydb411's Avatar
earls makes them or you can order them from napa. i've gone both routes.
Old Aug 8, 2003 | 03:42 PM
ek_will's Avatar
Default Re: (scttydb411)
it sucks soooo bad espically now that its a weekend and ordering parts will take days....im gona go around checking speed shops i found the banjo bolts they use for brake lines but their not the right size....hopefully ill find one
10mm x 1.25
if anyone knows of a specific shop that sells em or similar let me know
Old Aug 10, 2003 | 06:28 AM
ek_will's Avatar
Default Re: (dash0n)
bump anyone know anywhere else i might be able to find its a sunday no ones open im gona look again tomorrow btw how long will it take a shop to order me one
Old Aug 10, 2003 | 07:43 AM
ek_will's Avatar
ttt is it possible to drill my own hole through the bolt?
ADeKK
Aug 7, 2010 04:10 PM
DCRB
13
Mar 23, 2010 09:47 AM
aznryd3r
Apr 25, 2006 08:21 PM
B00STidDc5
Jan 28, 2006 05:53 AM
hellas
Jan 21, 2003 12:33 PM
