Which Precision Turbo for my setup?
Old Aug 7, 2003 | 09:30 AM
bo0sted's Avatar
Default Which Precision Turbo for my setup?
I've been doing a lot of research and I’m actually confused on which Precision turbo will be best for my setup.
Setup: (b18c1)
Full Race Front Mount Intercooler
Full Race 3" Down Pipe
40 mm Tial Wastegate
Lovefab Tubular Manifold
Hondata s200
Stock block (for at least a year)
I was leading towards the s50 .63 for my current setup at about 8psi on a stock block. But I’ve had a few people tell me just to get the SC61 instead of upgrading to it later on since they are the same price. How well would the Sc61 hold up on my stock block? Which turbo would you recommend and remember the block will be stock for atleast a year due to money.
Old Aug 7, 2003 | 09:43 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Which Precision Turbo for my setup? (MwGSR)
the sc50 has a weird compressor map. its not as efficinet as the sc61. go with the sc61 with the .60 front and a .48 rear or .63 rear. it will make plenty of power at 4-6 psi on stock block and youll have room to turn it up later and make more power. thats my advice.
Old Aug 7, 2003 | 09:52 AM
bo0sted's Avatar
Default Re: Which Precision Turbo for my setup? (MotorMatrix.com)
How fast would the sc61 spool up on a stock block? I'm guessing full boost at 4000rpm?
Old Aug 7, 2003 | 10:03 AM
bo0sted's Avatar
Is it even worth running the sc61 at 4-6 psi. I mean what kind of power would that put out compared to like a t3/t04e at like 8-9psi.
Old Aug 7, 2003 | 10:44 AM
ryu12341's Avatar
i say go with the sc61.
Old Aug 7, 2003 | 11:21 AM
93LSivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MwGSR &raquo;</TD></TR><TR><TD CLASS="quote">Is it even worth running the sc61 at 4-6 psi. I mean what kind of power would that put out compared to like a t3/t04e at like 8-9psi.</TD></TR></TABLE>
I put down 228 whp on my sc61 at about 4.5psi. This was untuned and probably running in the 10:1 afr area.
Old Aug 7, 2003 | 11:47 AM
symba's Avatar
Default Re: Which Precision Turbo for my setup? (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">
I put down 228 whp on my sc61 at about 4.5psi. This was untuned and probably running in the 10:1 afr area.</TD></TR></TABLE>
Damn, that kinda makes me want to sell off my t3/t3e and go with the SC61
Old Aug 7, 2003 | 12:47 PM
bo0sted's Avatar
Those are some nice numbers. What does everyone else recommend for me to do? 6psi on a stock b18c1 tuned on hondata should be around the 260-270whp mark then, i'm guessing?
Old Aug 7, 2003 | 02:09 PM
dmecarboy's Avatar
SC61, Get the right turbo the first time. I purchased the SC60 for my stock motor and boosted 12psi made 315hp. Built the motor and now making 435 @ 19 psi. Really wanted to break the 450 mark below 20psi. Now looking to get the SC61
Old Aug 7, 2003 | 02:53 PM
spooler's Avatar
Does the SC61 provide useable power for a 1.8L drag car? Or is it more of a dyno queen turbo? I have a built 1.8 and am looking for something that will provide gobs of useable 1/4 mile power.
Or would it be more like a bog off the line, then rip the tires apart. Obviously it provides a lot of Hp, but can you use it?
Old Aug 7, 2003 | 03:26 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Which Precision Turbo for my setup? (dmecarboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmecarboy &raquo;</TD></TR><TR><TD CLASS="quote">SC61, Get the right turbo the first time. I purchased the SC60 for my stock motor and boosted 12psi made 315hp. Built the motor and now making 435 @ 19 psi. Really wanted to break the 450 mark below 20psi. Now looking to get the SC61 </TD></TR></TABLE>
So are you saying that the SC60 is starting to run out of breath or are you just not happy that you didn't bust 450whp under 20psi??
Adi
Old Aug 7, 2003 | 03:41 PM
b18cTurbo's Avatar
Default Re: Which Precision Turbo for my setup? (newgsr)
ask arturbo for advise
Old Aug 7, 2003 | 05:10 PM
dmecarboy's Avatar
Default Re: Which Precision Turbo for my setup? (BlacKBeast2K)
By no means is the SC60 running out of breath! The turbo is very strong. I kinda wanted the numbers. My car pulls like crazy. Didn't really want to go past 20psi Not dead set on a new turbo (SC61) just doing the research!
Old Aug 7, 2003 | 05:11 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlacKBeast2K &raquo;</TD></TR><TR><TD CLASS="quote">ask arturbo for advise </TD></TR></TABLE>
What he said! Art da man y0!
Old Aug 7, 2003 | 05:19 PM
I am a bad person
Default Re: (spooler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooler &raquo;</TD></TR><TR><TD CLASS="quote">Does the SC61 provide useable power for a 1.8L drag car? Or is it more of a dyno queen turbo? I have a built 1.8 and am looking for something that will provide gobs of useable 1/4 mile power.
Or would it be more like a bog off the line, then rip the tires apart. Obviously it provides a lot of Hp, but can you use it?</TD></TR></TABLE>
you would need to get it built for drag then. i would recommend the .70 front with the .58 rear for drag. that way there is not much lag with the .58 but the front housing will flow what you need. you could go .60 front also. thats your choice.
Old Aug 7, 2003 | 05:23 PM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MwGSR &raquo;</TD></TR><TR><TD CLASS="quote">How fast would the sc61 spool up on a stock block? I'm guessing full boost at 4000rpm?</TD></TR></TABLE>
thats what i would like to know too. I plan on running...possibly the full race kit on my stock B18c1 for about 1 year as well until I can get it sleeved. I wanted to know that the powerband would look like.
also when will the turbo start and reach full spool on a stock B18c1?
Old Aug 7, 2003 | 05:28 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (MotorMatrix.com)
Actually its not the SC50 that has the strange compressor map, its the SC32 that I call "weird". The SC50 is a really effcient compressor, but not as good as the SC61. I say that for what you want to do get the SC61.
art
Old Aug 7, 2003 | 05:35 PM
I am a bad person
Default Re: (Arturbo)
i thought the 32 and 50 were the weird ones and the 54 and 60 had a strong map besides the 61. i guess i was wrong if you say so.
Old Aug 7, 2003 | 07:46 PM
bo0sted's Avatar
Everyone is saying the sc61. I'm pretty convinced on getting it now. Now the question what would be the best a/r size on my turbo?
Motormatrix recommended:
"60 front and a .48 rear or .63 rear"
Old Aug 7, 2003 | 08:06 PM
I am a bad person
Default Re: (MwGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MwGSR &raquo;</TD></TR><TR><TD CLASS="quote">Everyone is saying the sc61. I'm pretty convinced on getting it now. Now the question what would be the best a/r size on my turbo?
"60 front and a .48 rear or .63 rear"</TD></TR></TABLE>
the rear housing choice is yours. if you run your car hard on the street the .48 will burn tires endlessly. but it will have good spool for the track. the .63 will have more lag but not as much wheelspin. i run a .63 on my car and it works good.
Old Aug 7, 2003 | 08:10 PM
bo0sted's Avatar
when you say .48 will burn my tires endlessly, what do you mean by that. It's going to spool up too quick causing me to loose a lot of traction?
Arturbo's Avatar
Better than steak
25 Year Member
I agree with mike.
Old Aug 7, 2003 | 08:16 PM
I am a bad person
Default Re: (MwGSR)
yeah, i mean boost will come on so quick you will lose traction. the 63 will get you rolling a little more before fullboost so you get better traction on the street.
Old Aug 7, 2003 | 08:22 PM
TurboCX's Avatar
Get yourself the SC61 and run a .60 compressor and the .63 exhaust side. I'm running the SC61 with my GSR motor and it works great.
Old Aug 7, 2003 | 08:27 PM
bo0sted's Avatar
Default Re: (TurboCX)
Thanks guys. I know what to get now.
I will keep you all updated once its all put together.
Thanks again.
AlAddiN|502
Sep 22, 2010 06:28 AM
morgan@synapse motorsport
Feb 4, 2010 06:10 AM
salsero_utah
Nov 13, 2005 05:03 PM
xerox445
Dec 14, 2003 07:42 AM
