anyone dyno with v-afc hack?
Old Aug 6, 2003 | 09:56 PM
S2KP's Avatar
Default anyone dyno with v-afc hack?
Has anyone gotten their car dynoed with the V-afc hack? Post your setup and dynocharts
Old Aug 7, 2003 | 06:36 AM
scttydb411's Avatar
Default Re: anyone dyno with v-afc hack? (Turbo_Siii)
i dyno tuned my d16y7 with s-afc hack. stock 98whp...6psi 145whp and 138wtq. instant torque and doesn't drop off at all. nice smooth a/f ratio, but couldn't get it any leaner than 10.5-11 a/f ratio. i just got done street tuning with techedge wideband yesterday at 9psi. can't wait to check it on a dyno. it pulls like a ****.
Old Aug 7, 2003 | 06:58 AM
Bailhatch's Avatar
Default Re: anyone dyno with v-afc hack? (scttydb411)
Did you solder your techedge yourself? I really want to build one. It seems pretty straightforeward just kinda tedious to assemble. Do you have an A/F display or something else?
Old Aug 7, 2003 | 01:36 PM
scttydb411's Avatar
Default Re: anyone dyno with v-afc hack? (Bailhatch)
renting it from a friend, but he did build it himself. logging/display duties are from a palm. you can log a run just by tapping the screen on and off. then pull over to view the run to see how the a/f is in relation to rpm.
i just ordered a wideband sensor and about to order the new techedge 2.0 unit.
Old Aug 7, 2003 | 01:57 PM
spike's Avatar
how did he log rpms? i've been trying to figure out how to do that
Old Aug 7, 2003 | 06:08 PM
scttydb411's Avatar
i ran a tach line from the ecu to the techedge connector. the software on the palm pda has settings to graph/log and you select rpm and a/f.
Old Aug 7, 2003 | 06:22 PM
TurboDX's Avatar
Default Re: (scttydb411)
i have the hack on my dx(i know dont have v-tech yet) but i dynoed 161whp 158wtq @ 7psi on stock block and head...
Old Aug 8, 2003 | 07:30 PM
_jester_'s Avatar
I am waiting to put in my GSR cams, and to find somewhere here in Va. Beach that dyno's. This is worthless info but i felt like saying something. If i have time i'd like to dyno before the cams and after...so i can see if these damn GSR cams do anything for my boosted b16. Oh and if anyone who reads this knows of some good shops in Va. Beach.....email me, xratedsi@verizon.net
~peace
Old Aug 9, 2003 | 10:31 AM
TravSi's Avatar
Default Re: anyone dyno with v-afc hack? (XratedSi)
i dyno'd my d16a/z6 made 205whp@7000rpms and 160 ft.lbs of torque....this is on 6psi and im runnin the afc hack
Trav
Old Aug 9, 2003 | 10:57 AM
Chuck Dean's Avatar
I made 253 whp and 190 ft.lbs. @8psi on a B18C1 with the AFC hack.
Old Aug 9, 2003 | 12:20 PM
Slammd Sol's Avatar
I made 140 hp and 140 tq @ 5psi on my D15b7. T3 turbo, DSM 450s w/ SAFC, 2.5" turbo back.
Old Aug 9, 2003 | 01:07 PM
DOHCarp's Avatar
I dynoed with the v-afc hack (450 DSM's) first run was 173 whp then by the end of the dyno session I was at 268 whp. Im running into a little bit of trouble with the factory map going into limp mode cus im dumping so much fuel into it.
Forgot to mention its an LS/Vtec (stock block stock B16 head)
Old Aug 20, 2003 | 12:42 PM
SDT Project EF's Avatar
Default Re: anyone dyno with v-afc hack? (DOHCarp)
Dynoed with v-afc hack (dsm 450's) tdo5 14b turbo, hf manifold with adapter plate, 3inch downpipe, starion intercooler, stock internals see sig for numbers. I also had a problem at like 5500rpm each run i would get a check engine light for map sensor and car would run bad. Thinking the sensor is seeing boost. so i lose power at 5,500.
Old Aug 20, 2003 | 01:07 PM
boosted_dc2's Avatar
Default Re: anyone dyno with v-afc hack? (SDT Project EF)
259 @ 8100 bibc1 stock internals and head @ 7psi. rc 440's
Team 4
37
Apr 23, 2009 11:39 PM
sexyvtec88
Nov 19, 2007 03:28 PM
luap
Mar 16, 2004 01:08 PM
ActiveAero
Mar 3, 2003 11:58 PM
TurBoXBirD16
Jul 9, 2002 08:37 AM
